Nikon NEF files don't rotate. Bug?
Paul Wossidlo
processor: AMD
ram: 2GB
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: 15.6 inch laptop
Post by Paul Wossidlo »
I noticed my Nikon NEF files do not auto-rotate to portrait orientation for photos that are shot that way. All my other software (Nikon ViewNX2, Picasa, and Photoshop Elements) all orient the file properly.
Is there something I'm missing in the ASP settings?
If not, do other camera maker's RAW files have a similar problem?
I've also noticed that NEF files I previously "starred" in ViewNX2 will have the stars show up in ASP, but ONLY if they have 5 stars. Fewer stars, and they don't show up in ASP. Seems quirky.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Nikon NEF files don't rotate. Bug?
Post by afx »
Rotation works just fine for my D70,D200,D300 and D700 files.
No Idea about the stars, I don't use ViewNX for that.
cheers
afx
tigloo
System_Drive: Z
Post by tigloo »
Works for me as well (D7000). I have a problem that my lenses are recognized when using RAW but not when using JPG, but that's a different issue. :)
ormdig
motherboard: Asus Sabertooth X58
processor: Intel i7-950 3.72Gh
ram: 24Gb
Video Card: Nvidia GeForce 460
sound_card: Realtek HD audio
Hard_Drive_Capacity: 4.5 Tb
Monitor/Display Make & Model: HP LP2475w, HP LP 2065
Post by ormdig »
D90 and D7000 rotate automatically for me.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Did you enable the AUTO IMAGE ROTATION from your Nikon settings? I'm also using a nikon SRL and my images are not rotation automatically until I enabled that settings from the camera.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Paul Wossidlo
processor: AMD
ram: 2GB
Thanks to everyone who replied.
I'm using a D300 and a D70. For both cameras I have autorotate enabled, but I do not rotate the images when they are displayed on the back LCD.
After reading everyone's responses, I decided to go back and preform a test using straight-from-the-camera (both D300 and D70) files. What I found out is that straight from the cameras, ASP rotates the files correctly. But if I then call up the files in ViewNX2 (my preferred batch RAW processor prior to ASP) and edit them, the files are no longer rotated when I go back to ASP. I know ViewNX2 adds the edit information to the NEF file instead of using a sidecar file of some sort. Apparently in changing the NEF file, ViewNX2 messes up the orientation setting that ASP uses. So it shouldn't be a problem for any future assignments, I'll just have to watch whenever I go in to any images that pre-date ASP.
Thanks again!
Paul
afx
System_Drive: N/A
Post by afx »
Paul Wossidlo wrote:TWhat I found out is that straight from the cameras, ASP rotates the files correctly. But if I then call up the files in ViewNX2 (my preferred batch RAW processor prior to ASP) and edit them, the files are no longer rotated when I go back to ASP.
Welcome to the joys of undocumented reverse engineered raw file formats... ;-)
cheers
afx
RickHeath
Post by RickHeath »
afx wrote:Welcome to the joys of undocumented reverse engineered raw file formats... ;-)
And software that writes directly to your RAW files :roll: :shock:
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
Paul Wossidlo wrote: I know ViewNX2 adds the edit information to the NEF file instead of using a sidecar file of some sort. Apparently in changing the NEF file, ViewNX2 messes up the orientation setting that ASP uses.
I decided some time ago not to use any of Nikon's software, and this is a very good illustration of one of the main reasons why. (Poor UI and overall speed are others.)
F_P
thufor
System_Drive: B
Post by thufor »
Well, once you download images from the card directly (or using software that doesn't modify content of the files it downloads) you can always make them read-only so that nothing writes to them ;-)
