The error says as follows:
The program has encountered an unspecified error and has stopped funtioning.
Please contal Corel Technical Support and send the dump file for analysis.
C:\Users\Chris\AppData\Local\Temp\vstudio_1.6.2.69_20120208_185709.DMP
VideoStudio X3 Crashes while creating video file, with error
Re: VideoStudio X3 Crashes while creating video file, with e
Is this a new and different problem to the ones you have already raised - if not why have you started a new topic add this to the previous one - if it is a new problem then we need much more information - what are you doing - what are you doing it with.
You are not helping us to help you - all you are doing is creating confusion - if you want help please remember we can not see you or your computer, we do not know what you are doing and if you place what information you do give in various different topics we do not know where to look for it.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
If are using VS X3, then I would suggest that you make sure that you have all the updates installed. You can download the updates via http://www.corel.com/corel/pages/index. ... id=1000016
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
BadCo55
- processor: AMD Phenom II X4 965 Processor 4 CPUs 3.4GHz
- ram: 6144MB
- Video Card: NVIDIA GeForce GTS 250
- Hard_Drive_Capacity: 1tb
I apologize for the confusion, I tried to delete the other two posts, but didn't know how. Admins can now delete those posts if you want. I have uploaded a video to youtube: http://www.youtube.com/watch?v=R9peX67P ... e=youtu.be This shows what happens. Also, I've updated the software and there are no other updates I can download and install.
Viewing the youtube video seems to indicate using Mpeg1 codec, Not sure what this is as it creates a AVI file????
The frame size of 1280 x 720 is certainly not a standard for Mpeg1. although it seems to be associated with Bandicam as “Bandi MPEG-1 Video Decoder”
Try another video type, Motion Jpeg should do, the file sizes will be larger the quality should be better.
View the Settings/Presets, maybe Div X, Sony Vegas gives you Motion Jpeg.
Then you convert the 1280 Bandi video to 1920 x 1080. Mpeg4
Now during writing this reply I was rendering the Bandicam video and VS 13 throws an error and promptly disappears from my screen.
So yep I am having problems with video created with bandicam?
Ok
Try capturing to Sony Vegas for motion Jpeg.
Then using VS Share Upload to You Tube-Mpeg 4 HD to use 1280 x 720 frame size
Ok
BadCo55
- ram: 6144MB
How do i convert it to a MPEG 4 file?
Video Studio provides several Mpeg4 templates,
Share Create video File-Mpeg4 shows a few most may not be what you require but you can test them out.
I have already mentioned Share – Upload to You Tube, probably the best option (but has a file duration limit to 15minutes, I think) this will create a file using:-
MPEG-4 Files
24 bits, 1280 x 720, 25 fps
Frame-based
H.264 Main Profile Video: 5000 Kbps
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
After the file has been created simply close the youtube window.
Using Make Movie Templates Manager (to overcome the 15 min limit) will allow you to create your own template, this will show adjacent to the Custom option.
MPEG-4 Files
Frame-based
