a PSP guide to loving ASP
Tips, Tricks, and Results
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: a PSP guide to loving ASP
Post by afx »
Tadjio wrote:Right, we'll wash my dirty linen in public :D
I've seen dirtier ;-)
These are all defaults or starting points to be switched off if desired.
I suggest using presets instead and keeping the defaults to a minimum.
Trying to learn a new program with lots of stuff switched on by default can lead to quite a few hard bumps in the learning curve.
The NN + Raw Noise is an experiment as a 'starting point' for Noise Reduction - I plan to edit it later particularly once I know if I will Register NN. Does NN + Raw Noise do any harm?
not per se. They can complement each other nicely. My Oly XZ-1 needs that combo.
I keep reading that Sharpening is different in ASP from Bibble.
Yup. Bibble sharpening was ok, nothing special. AS sharpening is not really good as they put it in the wrong spot. I am very much hoping that they will fix that in the next drop.
WS always delivers better results, but in Bibble that was not always needed. In AS, the regular sharpening is not usable for anything larger than web pics in my eyes.
Yellow label and one star? That is my 'minimum' default for Raw Images from which I work towards 5 stars and a different label for JPGs and other output files.
But what's the difference between no star and no labels and one star+label by default?
The star and label will not signify anything in that case, so it might as well be left off.
What's wrong with my Crop parameters? How do you set Crop Fit by default?
There is no need to activate it, just keep the other parameters.
cheers
afx
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
cheers
afx
This camera is an Oly too! What are your default or preset settings?
I will try WS2 but perhaps wait for the next release of ASP.
All my Images CR2, ORF, JPG, TIF start with no Rating and no Label so I want to distingush the RAW ones that ASP has 'seen' and to which its Raw Defaults have been applied.
The Yellow Label tells me it is RAW (I can't outsort them in ASP File System) and the Rating tells me I have started the 'rating' process.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
afx
System_Drive: N/A
Post by afx »
I do no think the settingys of my P&S translate well to Micro 4/3 cam...
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
One new concept for us coming from PSP to ASP is that of the Image Processing Pipe line.
In PSP we had to make our own decisions on the sequence of editing actions, for example that Sharpening should be near to last.
In ASP/Bibble I have seen references to the pipe and stumbled across a list in the AfterShotPro.log that is written for each session.
This is numbered from 0 to 37 in my case, and includes for example:
0 : "UncompressedRawData"
1 : "RawNoise"
2 : "Demosaic"
10 : "NoiseNinja"
12 : "zPerspectorFilter"
15 : "Crop"
16 : "WhiteBalance"
17 : "AutoLevel"
18 : "Exposure"
19 : "FillLight"
23 : "WaveletSharpen2_Wavelet_Filter"
24 : "Sharpen"
26 : "PerfectlyClear"
27 : "Color"
34 : "Curves"
This list is helpful as a PPS guide to loving ASP.
Tadjio
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
Tadjio wrote: . . I have seen references to the pipe and stumbled across a list in the AfterShotPro.log that is written for each session.
This is numbered from 0 to 37 in my case, and includes for example: . . .
Yes, I've wondered about the pipeline references; interesting information.
The unanswered question - is the sequence a record of your operations in processing an image or does ASP process in that sequence the modifications that you choose? For me, the implication is that ASP controls the sequence. I guess one way to find out is to process two images using different order of changes and check the logs.
Mark
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
The pipeline is fixed. Its no difference if you e.g. Sharpen frist and modify the contrast later or vice versa, the results are the same.
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
DocBrown
Post by DocBrown »
Which is a wonderful thing because it takes the guess work out and allows you to just work the image. Another reason that ASP should be the first part of your workflow, even with JPGs and TIFFs.
Chuck
Lightroom 4.1, ACDSee 5 Pro, Neat Image 7, PictoColor iCorrect One Click
Canon EOS 20D, Canon EOS 7D
Visit my gallery: http://coldwater.smugmug.com/
JStanley
Post by JStanley »
deleted
Tadjio
sound_card: Sound
Post by Tadjio »
JStanley wrote:How does ASP enhance the PSP user experience?
If you take PSP as JASC left it, Corel have added new aspects / features, two of which I don't use as they are flawed if not broken.
The first is Raw Conversion. ASP enhances the PSP user experience with this alone.
The second is the (dis)organizer / Manage Mode. ASP enhances the PSP user experience by providing a workflow where you can manage and edit multiple photos.
Neither of these preclude the use of PSP as an Image eEditor.
Tadjio
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
JStanley wrote:I'm sorry, but after reading through this entire forum thread, I don't see why a PSP user should love ASP.
ASP simply gets the files in a state that you can work on them in PSP. But you've already been doing that some other way all along. If that other way was the pits then this fills the void.
The goal of course is to eliminate the need for PSP for those shots that ASP's tools are capable of handling, theoretically speeding up your process. But if you're like me you've already got another solution for that and this is just something new to learn.
From a PSP user's perspective (who isn't even fond of ASP) the main gist of it all is (and mostly not from this thread):
  1. Non-destructive. They'll beat that one till the cows come home. It will never save over the original file and will only add a secondary file to the same folder telling the program what changes/edits to make when you decide to output the file.
  2. Speed. When you actually do output your files it will zip along and be done in no time.
  3. Pipeline, which is the order that the edits will happen in. Often you'll see in forums or blog postings to eliminate the noise in the beginning of your workflow along with correct for color, with your sharpening last. With the pipeline that's already thought out and planned for the best outcomes.
  4. Undo/edit further anything. With the pipeline and the secondary file of edit commands in place you can undo whatever you want in your history of just slide the slider back to where it was to begin with or move it to a different position.
  5. It works on just about any system. Windows, Mac, Linux.
  6. It has better cataloging features than PSP does.
Now after saying all that I'm still just not as overwhelmingly impressed as I had hoped to be. Maybe I just had too high of expectations. I'm sure the Bibble people don't see a need for PSP much.
Regards, Dan
bobbert
What I really need is a workflow...
Post by bobbert »
Which product do I use as a digital asset manager and how do I go back and forth??
ASP doesn't see pspimage or psd files, and PSP's catalogue is not quite up to snuff as an asset manager especially when compared to ACDSee. I'd love to stay in the Corel family, and I'd be willing to drop ACDSee if the Corel products were better integrated.
So the best I can do right now is swallow hard and use PSP's catalogue, open RAW files in ASP, develop them and save as TIFF files, THEN do the fancier layers and Topaz processing back in PSP.
My workflow now is find, open and develop in ACDsee, save as hi quality jpg or tiff and finish up in PSP. A simpler workflow, and often I don't have to go to PSP as the developed files in ACDsee suit my purpose.
Do you think that ASP will ever recognize at least Corel's own file formats? Will it ever be a good DAM? If so It is worth the full price!
afx
System_Drive: N/A
Post by afx »
As AS runs rings around ACDSee and PSP for raw files, that makes it worth it.
The DAM component is a joke. Just ignore it.
chers
afx
grahamh
motherboard: Dell Inc. 0X231R A00
processor: Intel Core i7 860
ram: 6GB
Video Card: NVIDIA GeForce GT 220
sound_card: on board
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Samsung SyncMaster 2250
Post by grahamh »
That may be the case but none the less it should at least be capable. Whilst not able to compete with dedicated DAM software it should cope with the needs of those users who like me need a simple and reliable catalogue.
I hope with the new Corel expertise and resources this can be resolved after all, unlike raw development database solutions have been around for years. I am also unhappy with the way keywords are used when using keyword manager - it just seems over complicated, same goes for lens recognition which imo should offer the user a simple way to relate asp to the actual user lens needed.
tomsi42
Post by tomsi42 »
df wrote: ASP simply gets the files in a state that you can work on them in PSP. But you've already been doing that some other way all along. If that other way was the pits then this fills the void.
---8< snip 8< ---
Great summary.
df wrote: Now after saying all that I'm still just not as overwhelmingly impressed as I had hoped to be. Maybe I just had too high of expectations. I'm sure the Bibble people don't see a need for PSP much.
Bibble was never a Wow product; you needed to work with it to get the best out of it. But after learning it, I find the competition lacking.
For me Aftershot is a major improvement on Bibble 5, mainly because of the better support of my cameras. Other people, only see it as a make-up exercise as Bibble5 supports their cameras well. I do believe that a few service packs will fix the remaining issues and make Aftershot the product we wanted it to be.
I don't see ASP as a replacement of PSP, nor do I see any reasons for merging the two products. I do think that PSP is a good companion to ASP and will buy a license some time in the future.
bobbert
Post by bobbert »
All I want ASP to do is recognize file types other than RAW and jpg... pspimage is a must, PSD would help those who use Adobe products. Others here may suggest other file types; personally I don't use PNG files. But a catalogue should be just that - able to recognize every image file of any type in every folder and simply apply, keywords, categories ratings etc. ASP just needs to see all the file types for starters.
