a PSP guide to loving ASP
Tips, Tricks, and Results
B4b5
Re: a PSP guide to loving ASP
Post by B4b5 »
afx wrote: As usual, the keyboard shortcut and the menu entry work identical.
As I wrote elsewhere, your box is hosed if that is not identical.
Quite dismissive.
Maybe ASP is only working right on your Linux.
All other programs including PSP work perfectly on my Windows 7.
Wouldn't it be sad if everone elses Windows 7 computer is also "hosed"?
Could there be any value, or harm in having some Windows 7 people give it a try?
Anyway I know how to work around long standing Bibble/ASP flaws. So it won't mean much to me.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
Given the topic "a PSP guide to loving ASP" I thought I would chip in on the subject of setting and resetting settings to default.
I have been experimenting with the "Save as RAW default..." which creates the file "DefaultRaw.xmp" that is used whenever a new RAW Image is seen in ASP (if it is present).
I created this file by using the right-click Settings Option "Save as RAW default..." and checking the detailed settings I wanted, having first loaded a RAW Image and set-up the basic settings I wanted.
In my example, I set AutoLevel at 0.002 (rather than the default of 0.2), Sharpening, Noise Reduction, enabled Crop Fit and Lens Correction and set the Star Rating and Labels/Flags I desired for all RAW files.
This Default RAW set-up works fine for me, indeed 'I love it' and at any stage I can right-click either "Apply Initial Settings" or "Apply Default Settings" (Ctrl+R) to reset everything back, apart from Metadata (as afx points out).
I have two cameras, so I went on to create two more files using right-click "Save as Camera Default..." one for my Canon and one for my Olympus. This camera-specific file e.g. "DefaultRawCanon_Canon_EOS_550D.xmp" is used by ASP instead of "DefaultRaw.xmp" and so has to include everything in that. It is best created by loading a RAW Image, making any alterations and then saving as Camera Default.
In my case the Canon is Cropped 3:2 whereas the Olympus is 4:3 so I included this, together with some appropriate Metadata defaults such as my Copyright. I love this camera specific aspect of ASP. Again Ctrl+R at any stage resets ASP to the Camera Defaults for any Image.
I had hoped to force ASP to recognise my Olympus Lens (by telling it that it is another similar calibrated one) but even though I have put the Metadata Lens in the Camera Default it is not loaded initially, but only when I press Ctrl+R.
For fear of frightening anyone I will stop there. Any questions?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Quite dismissive.
My prime imaging machine runs W7 pro 64 bit. Linux is run on my laptops when I am on the road (which is more time than the time spent at home on the big box).
You are the only one reporting this keyboard/menu discrepancy which is a strong indication that this is isolated to your box.
Further indication is your statement about selective copy not popping up a window to choose what to copy...
cheers
afx
afx
System_Drive: N/A
Post by afx »
Tadjio wrote:I had hoped to force ASP to recognise my Olympus Lens (by telling it that it is another similar calibrated one) but even though I have put the Metadata Lens in the Camera Default it is not loaded initially, but only when I press Ctrl+R.
That sounds like AS already has seen the file (it as an XMP, DB or cache entry) so you need CTRL-R to force it to got to the defaults.
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
cheers
afx
No. That is what I thought at first but I tested it quite carefully with a brand new file.
Any other thoughts?
Tadjio
afx
System_Drive: N/A
Post by afx »
Can you post your defaults please?
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
afx wrote:Can you post your defaults please?
cheers
afx
I was just thinking of doing so!
The two relevant lines are:-
bopt:profilelens="Micro 4/3 Zuiko Digital 14-42mm F3.5-5.6 ED"
bopt:lens="Micro 4/3 Zuiko Digital 14-42mm F3.5-5.6 ED"
Under Lens Correction and Metadata, the word 'Lens' appears until I click Ctrl+R :(
Would you like the whole file?
Tadjio
afx
System_Drive: N/A
Post by afx »
Yes please
afx
Tadjio
sound_card: Sound
Post by Tadjio »
This my DefaultRawOlympus file:
DefaultRawOLYMPUS_IMAGING_CORP__E_PM1.zip
DefaultRaw file
(993 Bytes) Downloaded 968 times
I have inserted blank lines for clarity but if anyone can tell me how to annotate comments, I would be grateful.
<!-- comment --> doesn't seem to work...
Tadjio
afx
System_Drive: N/A
Post by afx »
Strange. Guess my first test was flawed.
I can confirm your observation. The lens is not picked up by the default in contrast to the other settings.
Time for a bug report.
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
afx wrote:Strange. Guess my first test was flawed.
cheers
afx
Thanks for trying.
Any suggestions for commenting my default file?
I intend to edit it from now on, rather than re-create it from scratch and I want to remember what I have done in years to come :D
Tadjio
afx
System_Drive: N/A
Post by afx »
No, it never occurred to me to play with comments in there... my defaults are rather slim.
If standard XMP comments don't work, I do not think there is a facility for that.
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
afx wrote:No, it never occurred to me to play with comments in there... my defaults are rather slim.
cheers
afx
Thanks anyway.
As you can see, I have enough entries in my default file to justify comments, especially as it is all new to me...
Tadjio
afx
System_Drive: N/A
Post by afx »
Tadjio wrote:As you can see, I have enough entries in my default file to justify comments, especially as it is all new to me...
There is way too much stuff in there in my eyes.
For example, do you really need NN + Raw Noise on all images? That sensor is not that bad is it?
And using WS by default without turning off regular sharpening can lead to rather nasty artifacts.
Why are all images tagged with a yellow label and a star by default? Shouldn't that happen after initial judgment?
Why is crop enabled by default when the aspect ratio fits the sensor anyway? Why not just set the aspect ratio as a default but leave it disabled?
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
cheers
afx
Right, we'll wash my dirty linen in public :D
These are all defaults or starting points to be switched off if desired.
The NN + Raw Noise is an experiment as a 'starting point' for Noise Reduction - I plan to edit it later particularly once I know if I will Register NN. Does NN + Raw Noise do any harm?
I am still exploring Sharpening, especially as I have lost my default sharpening in Canon and my HPS in PSP. I shall probably try WS2 instead. I keep reading that Sharpening is different in ASP from Bibble.
Yellow label and one star? That is my 'minimum' default for Raw Images from which I work towards 5 stars and a different label for JPGs and other output files.
What's wrong with my Crop parameters? How do you set Crop Fit by default?
Tadjio
