I've realised to my horror that I can't do that in ASP
What's the point in commiting to a program to manage all my precious assets if I can't drag'n'drop out of it?
Do I have to open Windows Explorer (or ZoomBrowser) in order to do so?
Tadjo:Tadjio wrote:One of the things that I do a lot is drag and drop images between programs.
I've realised to my horror that I can't do that in ASP![]()
Yes.MarkZ wrote:Tadjo:Tadjio wrote:One of the things that I do a lot is drag and drop images between programs.
I don't understand - can you give an example? Do you want to drag a file in File System into another program such as PSP?
Mark
You have put your finger on it.kaymann wrote:... and there is no copy and paste function in ASP neither...
I am not saying it shouldn't happen I am just saying apparently there is no structure behind it right now....
For what?Tadjio wrote:I think ASP could (should) have the structure in place to 'render' any image so that it can be copied and pasted or dragged and dropped either within ASP or out to another program.
Because I like to use my assetsafx wrote:For what?
Only in the File System as Drag'n'Drop not Copy&Paste, and not in the Library Catalogs at all, which is inconsistent.afx wrote:And within ASP it already works.
Copy and paste is much more useful for image settings don't you think? How often do you do that with files vs. image settings?Tadjio wrote:Only in the File System as Drag'n'Drop not Copy&Paste, and not in the Library Catalogs at all, which is inconsistent.afx wrote:And within ASP it already works.
To be honest, I haven't yet tried to copy image settings yet. For me Ctrl+C still means Copy File!afx wrote:Copy and paste is much more useful for image settings don't you think? How often do you do that with files vs. image settings?
It would be totally broken to waste the usual keys for files (and inconsistent with any other raw converter or DAM for that matter that also use those keys for various settings).
afx wrote:Let's worry about that fix when the basics work.
cheers
afx
Tadjio wrote:My suggestion/frustration cannot be solved in ASP v1 SP1 but perhaps in v2.
This statement of yours worries meafx wrote:And who cares about moving files in a DB that is not usable anyway....
afx
Did you try that in Office yet?Tadjio wrote:To be honest, I haven't yet tried to copy image settings yet. For me Ctrl+C still means Copy File!
Does not really fly in the context of this application. You can already move or copy via the mouse.I'm not suggesting a change of use for the keys, but a right-click (Edit) context menu option to Copy (or Cut) the Image File and another to Paste it, as well as my suggestion for Drag'n'Drop to other programs.
Nothing like that....Tadjio wrote:This statement of yours worries meafx wrote:And who cares about moving files in a DB that is not usable anyway....
afx![]()
Are you saying the embedded SQLite databases are suspect or (as I presume) that the Library Catalogs in ASP are neutered ?
Nothing. The catalogs in Bibble where already stillborn, basically the limited same functionality.What could one do in Bibble that you now cannot do with Catalogs in ASP?
That already worked in B5.I did read your note that Metadata searches can now span multiple Catalogs in the Library.
What did you mean by items 2 and 5 in the above list?afx wrote:Some hints for reoccurring questions....[from Bibble forum]
Changes B5->AS
Some more changes in AS over B5:
- Autolevels was moved further up in the pipeline so it is less sensitive to changes.
- Catalogs are now by reference only.
- Plugins have access to EXIF information
- Double clicking on an image will zoom to 100% with the cursor position centered
- Watched Folders are gone
Useful to know.afx wrote:In contrast to other programs, Bibble can search and work with all open catalogs.
Therefore you do not need to stuff all your images into one catalog.
B5 had catalogs where files where moved into it. A rather silly idea.Tadjio wrote:[*]Catalogs are now by reference only.
B5 could monitor folders for new files and execute batch queues on them.[*]Watched Folders are gone
That is still the same in AS.I also read the following, assuming it only related to ASP:afx wrote:In contrast to other programs, Bibble can search and work with all open catalogs.
