Adding text
Jim Gordon
motherboard: Gigabyte Technology Co.
processor: 2.80 gigahertz Intel Pentium 4
ram: .98GB
Video Card: Intel
sound_card: Realtek
Hard_Drive_Capacity: 160 GB
Monitor/Display Make & Model: Samsung SyncMaster
Adding text
Post by Jim Gordon »
I have just added the plugin "z Text" to AfterShot Pro but when I try to get more info as to how to use it the site does not exist.
How do I add text to AfterShot Pro ? It looks like I need to do it in Paint Shop Pro then move it to AfterShot Pro, then use the plugin.
Just what are the steps I should use? Thanks Jim
derouyag
processor: Intel Core2 Quad CPU Q6700 2.66GHz
Video Card: NVidia GeForce 8800 GT
Hard_Drive_Capacity: 11TB
Monitor/Display Make & Model: HP w2408h (Dual)
Re: Adding text
Post by derouyag »
zText
1. Open ASP
2. Goto PlugIns tab - find zText (assuming you installed it.)
3. Just below the title, enter your text
4. Choose a font
5. Play with the sliders for the position (within this layer... Each layer can have separate text)
6. Click on the other tabs: Basic, Transform, Preset, and Shadow for more options.
Sorry if I am not detailed enough for you because I am new to zText too.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Adding text
Post by afx »
Jim Gordon wrote:How do I add text to AfterShot Pro ? It looks like I need to do it in Paint Shop Pro then move it to AfterShot Pro, then use the plugin.
Sounds messed up....
Install the plugin in AS, Select an image, navigate to the plugin, enter text, select a font and push the sliders until the location is right...
cheers
afx
B4b5
Re: Adding text
Post by B4b5 »
Jim Gordon wrote:I have just added the plugin "z Text" to AfterShot Pro but when I try to get more info as to how to use it the site does not exist.
Check the box next to zText.
Type something in the dark grey space below zText
Select a font from the drop list, and your good to go.
Jim Gordon
ram: .98GB
Video Card: Intel
sound_card: Realtek
Re: Adding text
Thanks,I now have it working.Jim
