importing images
charles45
- processor: celeron cpu 2.66 GHz
- ram: 1920 Megab
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: DELL E177FP [Monitor]
importing images
Hi All.
Can somebody show the way how i can import my images from my camera directly into ASP?I see other ways but not directly from my camera.
thanks in advance.
regards,charles
thanks in advance.
regards,charles
Re: importing images
I think the Brand / Model "MyCamera" is not yet supported.
You may want to provide some more information about the Cam and how you import your images right now.
charles45
- ram: 1920 Megab
your 're wright i forgot to put the type of camera,it is Canon rebel T3i.
thanks for your remark.regards,charles
afx
- System_Drive: N/A
- Video Card: FirePro 4900
If it supports mass storage mode, plug it in and run the download queue on the mount point/drive.
if not, use the downloader provided by Canon.
Or instead of wasting camera battery and suffering slow downloads, get a decent card reader and use that.
cheers
afx
cheers
afx
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Charles:
Perhaps what is missing here is that what you need to do is download your photos into a directory (folder) on you computer using any of the ways afx mentions. Once there, the photos are available to be worked on by ASP or any other application, such as Picasa or whatever you have been using. You do not import into the application.
Mark
Mark
Mark
B4b5
The way I do it might be a little primitive but easy to manage.afx wrote: Or instead of wasting camera battery and suffering slow downloads, get a decent card reader and use that.
cheers
afx
I take the SD card out of the camera and plug it directly into my computer.
Then using nothing more than Windows Explorer navigate to the SD card and copy the files to some useful folder.
It's probably a bad idea to develope the image right on the card because the camera won't know what to do with the .xmp
When finished I put the card back in the camera - first thing I do is delete all images and I'm ready to start over.
afx
- System_Drive: N/A
Quite a waste of time in my eyesB4b5 wrote:The way I do it might be a little primitive but easy to manage.
Using a download queue all of that becomes much easier, no need to create a folder or rename files explicitly. The queue does it all for you.I take the SD card out of the camera and plug it directly into my computer.
Well, who would do that????It's probably a bad idea to develope the image right on the card because the camera won't know what to do with the .xmp
cheers
afx
MarkZ
- ram: 8 GB
Henry:B4b5 wrote: When finished I put the card back in the camera - first thing I do is delete all images and I'm ready to start over.
The only thing I do differently is format rather than delete. I believe it leaves the card in a better state.
Mark
Mark
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
I'm not sure if this is what you are looking for but AfterShot has a Import feature that will add your photos to a catalog. You can visit http://pnoy.me/lN for more information.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
charles45
- ram: 1920 Megab
Hi All.
If I understand it right,ASP does not have same import possibily as lightroom?and other Raw converters?
thanks in advance.
regards,charles
thanks in advance.
regards,charles
Zrubi
- System_Drive: N/A
- ram: 4GB
- Video Card: nVidia GTS 250
- Monitor/Display Make & Model: DELL U2311H
I think charles45 (just like me) missing a feature existed in B5: Move/Copy files while importing into a catalog.
It was a great thing, not needed to any other program just for rename, assign them in to the right folder structure, and import to a catalog...
Now with AS you HAVE to rename, arrange, store in a file system your RAW photos before you can start to develop them... :(
Right now in AS the "catalog" is just a joke - for those who have not using other programs for catalogue - it is pretty useless.
ogrizzo
- System_Drive: Q
- processor: 2.8 Ghz Intel Core i7
- ram: 8 GB
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Integrated Apple iMac 27"
The only difference between B5 and ASP is that catalogues only work by reference; sure as hell you can still develop images without using a catalogue!Zrubi wrote:Hi,
ashmoore
- System_Drive: N/A
- ram: 16G
- Monitor/Display Make & Model: iMac 27"
the download queue does work, but lordy is it SLLOOOOOWWW
I use ImageIngester which tags, copies and create backups faster than B5 would get half way through the first copy.
ImageIngester also tracks card usage, customer and job names, auto creates folders and tags based on that data, which neither B5 or ASP will do
You want a path like /Work/2012/customername/jobname/card/daydate/image<seq>.ext - no problem.
ASP download queue doesn't even come close.
old Bibble user
Hmm is that (old) Bibble user or (old Bibble) user?
ChrisC
- motherboard: Intel HM65
- ram: 8 GB DDR3
- Video Card: AMD Radeon HD6770M
- sound_card: Beats Soundsystem
- Hard_Drive_Capacity: 750 GB
- Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
I think this is a little bit misleading to new AS users. While I agree that there are more advanced solutions available, AS can very well auto create folders and file names based on dates, exif, IPTC, metadata, sequences and jobname.ashmoore wrote:... job names, auto creates folders and tags based on that data, which neither B5 or ASP will do
The list of possibilities can be found here:
http://product.corel.com/help/AfterShot ... rmats.html
Zrubi
- System_Drive: N/A
- ram: 4GB
Yeah. But if you NEED the catalogue feature as I did in B5 you do not want any other program just to download, and rename files...ogrizzo wrote: The only difference between B5 and ASP is that catalogues only work by reference; sure as hell you can still develop images without using a catalogue!
Download queue is originally not designed for this task...
Referenced catalogue is a tricky thing and if it will be the ONLY catalogue type it's bring some question:
- what if I put some new files into the file structure?
I have to remember for all the new files and import them?? Or just reimport the whole directory structure??? Not sounds to a real solution at all! - what if the filesystem and the database is out of sync?
It WILL happen frequently for sure, because You HAVE to poke the files with other software.
But me - and the others around there - who were happy (okay there was also a lot of things to improve) with B5 catalogues... what can we do?
Keeping B5 for a while.
