[BUG] ASP deletes wrong file(s) ?!
maggus
operating_system: Linux
System_Drive: B
Post by maggus »
I know, this bug was reported also in some other thread for ASP (and I think also for Bibble in the past), but I now hit it again and just extracted the related part from the ASP log-file.
Usecase:
  • Filesystem-Mode, Multi-Image-View OFF.
  • I think I had selected the picture "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.CR2"
  • then I changed to folder "/tmp/_markus_/foto/_RAW_Test/raw/"
  • I selected the file "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
  • then I continued selection with <CTRL> pressed on all the other names "*_lzn.jpg", so I had multiple files in this folder selected.
  • I pressed <DEL> to remove/delete these "Master Versions"
  • the popup told me that just 1 Master-Version is selected ... and I hit <OK> before I understood what´s going on .... sometimes the <ENTER> is faster then the speed of brain :oops:
  • only one file got deleted, the selected files were still there :!:
  • I looked into the ASP-log to find out WHICH file I deleted by accident (really good that there is a log-file !!! So I could easily find the deleted file in my trash and could restore it
So far I did not try to reproduce, but I can remember that I´ve seen it already once or twice in the past ... and also other users already complained about it.
To me it looks like a bug in the UI handling .... some delayed update of what ever maybe due to background extracting and decoding of images in a folder which is not yet in the cache ... :?:
Code: Select all
56498.965: Adding master versions
56499.141: Adding master versions
56499.142: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738.CR2"
56499.151: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738.CR2"
56499.183: Found XMP for /tmp/_markus_/foto/_RAW_Test/raw/IMG_0738.CR2 with 1 versions
56499.200: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
56499.203: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
56499.223: defaults:  "DefaultRendered.xmp"
56499.308: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739.CR2"
56499.310: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739.CR2"
56499.327: Found XMP for /tmp/_markus_/foto/_RAW_Test/raw/IMG_0739.CR2 with 1 versions
56499.342: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739_lzn.jpg"
56499.344: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739_lzn.jpg"
56499.398: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740.CR2"
56499.400: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740.CR2"
56499.413: Found XMP for /tmp/_markus_/foto/_RAW_Test/raw/IMG_0740.CR2 with 1 versions
56499.428: Scanning file  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg"
56499.430: Importing: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg"
56499.451: Found XMP for /tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg with 1 versions
56499.948: Adding master versions
56499.972: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738.CR2"
56500.365: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
56500.366: Decoding RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738.CR2"
56500.373: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739.CR2"
56500.655: Decoding RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739.CR2"
56502.456: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
56502.745: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740.CR2"
56502.823: Decoding RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740.CR2"
56503.442: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg"]
56503.530: Extracting RAW data: "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739_lzn.jpg"
56504.53: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg"
56509.269: LensDB::getCoefficients() - Couldn't find lens Lens
56509.410: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0738_lzn.jpg"
56511.158: LensDB::getCoefficients() - Couldn't find lens Lens
56511.300: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0739_lzn.jpg"
56511.973: LensDB::getCoefficients() - Couldn't find lens Lens
56513.138: Extracting RAW data:  "/tmp/_markus_/foto/_RAW_Test/raw/IMG_0740_lzn.jpg"
56515.431: trashing "/data/markus/.AfterShotPro/cache/assets/data/pictures/_FotoWork/__Winter/raw/.cache.noindex/{8da2ee2e-7c88-5843-8213-b75bba4d06ca}.prv.noindex"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.WAV"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.THM"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.XMP"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.CR2.BIB"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.wav"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.thm"
56515.431: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.xmp"
56515.432: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.CR2.bib"
56515.432: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.CR2.xmp"
56515.432: trashing "/data/pictures/_FotoWork/__Winter/raw/IMG_3978.CR2"
56516.210: LensDB::getCoefficients() - Couldn't find lens Lens
56717.423: set sort order ascending
Would be nice if this could be acknowledged by someone else and gets fixed in some point of time.
best regards
Markus
OpenSuse 11.4 (32bit)
Dell U2410
dFlyer
System_Drive: N/A
Re: [BUG] ASP deletes wrong file(s) ?!
Post by dFlyer »
Bugs need to be reported here:
https://www.surveymonkey.com/s/ASPFeedback
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
maggus
System_Drive: B
Post by maggus »
dFlyer wrote:Bugs need to be reported here:
Thanx, just reported via this link.
cheers
Markus
Dell U2410
Autark
System_Drive: B
ram: 3GB
Post by Autark »
maggus wrote:[...]I looked into the ASP-log to find out WHICH file I deleted by accident (really good that there is a log-file !!! So I could easily find the deleted file in my trash and could restore it
Just an observation: in my experience, simply undoing a deletion will restore all deleted files, accident or not. So normally you would not need to hunt them down like that.
maggus
System_Drive: B
Post by maggus »
Hi Autark,
thanx, I really did not think about the "undo" option .... will give it a try the next time.
But the look into the LOG file at least told me that it really deleted the wrong file while already scanning in the "new" folder.
cheers
Markus
Dell U2410
maggus
System_Drive: B
Post by maggus »
update:
Observed similar issue with <INS> key to create a new version.
Just refer my post: same with <INS> key !.
Dell U2410
