I thought that would make a good preset, but I cannot figure out how to make a preset that contains a layer. I see I can include layers in a selective copy but not when creating presets. Is that a know limitation?claudermilk wrote:What a good idea. Wonder if that would do anything with the hyper-aggressive Autolevels/Autocontrast problem? Time to play...Tadjio wrote:One tip I like is to use Perfectly Clear on a Layer and then reduce the Opacity to reduce the Aggresiveness...
Layers in presets?
Layers in presets?
From another thread:
tundraquad
- System_Drive: N/A
Re: Layers in presets?
I cannot neither.
for instance, my copyrights text contains quite often 2 lines. Since zText supports a single line text only, I created 1 preset per line that must be applied to separate layers. Unfortunately, I must manually create the layers prior to applying the presets. This procedure must be repeated to each image that I must copyright. It's not fun & it slows down my work-flow. I hope this will be improved in the future.
Thanks for bringing that up!
andysalay
- System_Drive: Z
- motherboard: ASUS P5E WS PRO
- processor: Core2 Quad Q6700
- Video Card: AMD Radeon HD 6670
Me too.tundraquad wrote:I cannot neither.
I often used polygons on layer with large feather for ND filter. (I know about other solutions, but this gives mi greater accuracy and ability to tweak everything including denoise).
I too was unhappy when realized presets cannot create layers with objects.
Andy Salay
@Tundraquad - Are you aware that you can use selective copy (CTRL+SHIFT+C) to copy multiple layers which you can then paste into multiple images? So you can set up 1 image and paste identical layers into as many as you want in 1 go.
Regards
Rick.
Regards
Rick.
tundraquad
- System_Drive: N/A
Hi RickHeath,
Yes, you're right! It actually saves me a lot of time doing such when I use the text in the exact same location.
The problem comes in when I use the text on imgs from cameras having a different resolution (I use D200/300/700s which have a different sensor), or more often when I position the copyrgt text at a different location. The main waste of time is when moving the text around.
... Actually, you're giving me an idea! I should create several generic images (somewhere in a specific catalog) with many scenarios, & use them as templates! ... He, why not! ... Thanks RickHeath!!
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Use Typewriter instead. It supports multiline text.tundraquad wrote:for instance, my copyrights text contains quite often 2 lines. Since zText supports a single line text only, I created 1 preset per line that must be applied to separate layers.
cheers
afx
tundraquad
- System_Drive: N/A
Hi afx,
Yes, I agree. I was used to Ghostwriter 1st, then TypeWriter. But in December I was concerned about how long Typewriter would be supported for. So, I transited to zText thinking that it will be maintained in the longer future.
afx
- System_Drive: N/A
Well, Sadman did produce an AS version, so I think that is not an issue anymore (I am using it for my watermarks).tundraquad wrote:Yes, I agree. I was used to Ghostwriter 1st, then TypeWriter. But in December I was concerned about how long Typewriter would be supported for. So, I transited to zText thinking that it will be maintained in the longer future.
He just needs to get around to make it more public ;-}
http://support.bibblelabs.com/forums/vi ... 66#p100266
cheers
afx
tundraquad
- System_Drive: N/A
Caramba !!
How did I miss that!
Well done Sadman!. See you in the Bibble forum.
Thank you SO much afx!
B4b5
Here's how I tamed the hyper-aggressive Autolevels:claudermilk wrote: What a good idea. Wonder if that would do anything with the hyper-aggressive Autolevels/Autocontrast problem? Time to play...
bopt:hasSettings="true"
bopt:shadowval="0.002"
bopt:highlightval="0.003"
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
I have done the same thing in my Default files, as 0.002 and below has no effect on the image.B4b5 wrote:Here's how I tamed the hyper-aggressive Autolevels:
The trouble is that I find I then end up changing the 2 to a 3 to a 4 etc, and then .002 to .02 to .2 until AutoLevel kicks in.
Not very productive 'trial and error'
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
B4b5
Hi Tadjio;Tadjio wrote:The trouble is that I find I then end up changing the 2 to a 3 to a 4 etc, and then .002 to .02 to .2 until AutoLevel kicks in.
I don't use Autolevels very much, but as a default I keep it off (false) and use the numbers given above only because they seem to be at the threshold
of a nice little response for the images from my camera.
I regard Autolevels like cholesterol medicine - a little goes a long way - a whole lot more isn't necessarily a whole lot better.
benoit
- System_Drive: N/A
- motherboard: Gigabyte GA-MA785GMT-UD2H
- processor: AMD Phenom II X6 1055T
- Video Card: integrated
- sound_card: integrated
- Hard_Drive_Capacity: 4.2TO
- Monitor/Display Make & Model: LaCie 324 and DELL 19''
Or use zText with the escape breakline sequence : '\n'tundraquad wrote:Hi afx,
my signature preset is using ztext with the following :
'@ E de Maistre\n%HEADLINE%\n%DATE%'
In the picture I am lookin at now it gives the followin with very nice layout :
@ E de Maistre
Mariage Céline et Julien
2011-09-17
Regards
