Chapter thumbnail Frame VSX4
wiseant
Post by wiseant »
Wondering if it is possible to change the default Frame that is used for displaying thumbnail chapters when I create my Menu for Blu-ray authoring
The existing Frame that has the Polaroid /postcard look with a paperclip, etc
If so, how does one replace this frame?
TIA
Re: Chapter thumbnail Frame VSX4
Post by BrianCee »
Unfortunately with Blu-ray discs this does not seem to be possible yet - it is in all standard templates so perhaps it will come to blu-ray.
In the meantime the only alternative seems to be to select a different menu template with a thumbnail frame which is to your liking - it does not matter which one you start with because you can change the background picture and hide other objects you do not want to create a very personal menu page.
wiseant
Post by wiseant »
@BrianCee
Thanks for your information. Perhaps I have overlooked something, but the available templates have the same thumbnail frame. I have used different backgrounds and hide/removed other objects, and it appears to me that in order to use chapter thumbnails I have to use this [thumbnail] frame.
Any other information is appreciated . . .
TIA
Post by BrianCee »
When I look at my Bluray menu templates I have the choices shown in the attachment - the thumnails on the bus - or with the white flower are not the same as that 'Polaroid' one - do you not have the same choice ?
wiseant
Post by wiseant »
@BrianCee
Thanks again Brian.
Yes, once I downloaded and installed the latest menu pak - all of these are there
I also noticed that I have a wider selection of frames and menu layouts - this is exactly what I was looking for - impressive!
TIA
