Precise texturing, outlining, & multi-side texturing
Torrianthane
operating_system: Vista Ultimate
motherboard: Acer EM61SM-EM61PM
processor: AMD Athlon 64 X2 Dual Core 3800+ 2.00Ghz
Video Card: NVIDIA GeForce 6150SE nForce 430
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 54.21 GB
Monitor/Display Make & Model: DELL 2208WFP 22.0"
Post by Torrianthane »
Morning,
Is there any way to do the following?
(1) More precise texturing: besides the obvious methods of texturing (using an image as the "color-fill" for objects and text), is there a more precise way to texture, or skin, text/objects so more user-controlled detail can be applied to certain parts?
(2) Is there a way of coloring/texturing an outline to text? What I have been doing is importing vector text into MS3D, then applying a texture or color, but is there a way to have an outline applied to the text while maintaining the appearance of the inner part?
(3) Is there any way of making the various sides of extruded text different colors? For example, the face of your text white while having the perimeter a red color?
Thanks for the help!
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: Precise texturing, outlining, & multi-side texturing
Post by Kingston »
For multi-side texturing, select the sides you want to change, or deselect the sides you don't want to change.
Don't have any suggestions for your other questions.
You do not have the required permissions to view the files attached to this post.
Use the same method described by Kingston in his post above. You select the side(s) you want to change the color or texture. A big part of this is having a Bevel. By default there is no bevel applied. Go to the Attribute Panel and from the drop-down menu select Bevel, and then choose one of the bevel templates. I would say for the type of effect you're after, using a Chiseled-Round or Round-Chiseled would work.
