Cropping - How to Set Default to Custom
jpmccormac
Post by jpmccormac »
Every time I click on the Crop Tool in ASP the default is "1.5 2:3 4x6 35mm" aspect. I like to use the custom setting for most images. Is there any way to set the crop tool to the Custom setting? I can't seem to find anything in the Help file or Preferences. Thanks.
"All who wander are not lost."
B4b5
Re: Cropping - How to Set Default to Custom
Post by B4b5 »
Select an image, then click on the "Crop" tool at bottom left of your workspace...
Then click on the bar that has 1.50 etc.. the top of the drop down list has "Custom"; click on it.
Now you can randomly change the aspect of your crop.
Alternatively you can just unlock the aspect ratio of the crop tool.
If custom is what you usually use you can add it to a preset that you can apply to all, or just some of your images.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Crop defaults can be defined just liek any other image defaults.
In this case set crop to custom but do not activate it when saving image defaults.
cheers
afx
jpmccormac
Thanks for the tips. I think the easiest solution - for me - would be to have the Crop Tool default to UNLOCK. This doesn't seem possible in the custom crop settings I made or in the Preferences settings. Am I missing something?
afx
System_Drive: N/A
Post by afx »
jpmccormac wrote: Am I missing something?
The lock aspect tickmark in the save preferences dialog....
cheers
afx
jpmccormac
After almost 20 years of using Paint Shop Pro, etc. I really feel stupid using a Crop tool in ASP that seems so unintuitive. :(
Here's what I do. I enable Crop > Custom. Then Control-Right Click the thumbnail, open the Settings menu and select Save as Rendered Default and go to the Crop option. Then What? Is this where I tick or untick the Lock Aspect. Which options allow me to do a free-hand crop for all subsequent images? Thanks.
The lock aspect tickmark in the save preferences dialog.... <<<<<< Which is where???
cheers
afx
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
right there ...
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
afx
System_Drive: N/A
Post by afx »
jpmccormac wrote:After almost 20 years of using Paint Shop Pro, etc. I really feel stupid using a Crop tool in ASP that seems so unintuitive. :(
It all depends on whyt you're used to ;-)
The tickmarks in that dialog just specify which option is to be saved. Not the value of the option. That is taken from the current image.
So the tickmark for lock aspect needs to be ticked. And if you set the corp tool appropriately before this step, the value should show false.
cheers
afx
