[quote="maggus" you´ll have to combine some of the steps:
- slightly modify the WB
- increase exposure to push the real overexposed parts to WHITE (or use the curve to do so)
- apply color correction (lower saturation) for this color
- en-/disable HR
[/quote]
Thanks Markus. I posted to Corel Support and didn't like how they chase to close an open case. But they provided one tip.
[quote]
You might need to use your camera's color profile for your photos. To do this, check the 'Custom Input Profile' under 'Color Management then select your camera's ICC file.
[quote]
I didn't know there was a Colour Management adjustment OUTSIDE of the general options screen for the program.
I did that and then sometimes not and for subsequent photos from different sessions, I no longer had the problem.
I may have also done some of the points you described (just read your post now) and that may have affected the result.
The other day, I saw a tick box in one of the panels "set the recovery to monochrome" - haven't fiddled enough to say whether that improves or not.
Thanks for listening.
