ASP does a good job of fixing lens distortion for some of my wide-angle lenses (for example it does a fine job with my Canon 15-85mm lens), but it does not support my Sigma 10-20mm wide-angle. So some questions.
Is there a list somewhere of what lenses are supported?
Is there some way for a non-professional like myself to determine what the proper settings are for common lenses so that I could enter the settings manually?
I have to admit that I am surprised that the Sigma 10-20, which is a common lens, is not supported already by ASP. Or is it supported and I am not doing something I need to do?
Lens correction supported lenses
MikeFromMesa
- System_Drive: N/A
- processor: 3.0 GHz Intel Core i7
- ram: 16 GB
- Video Card: Intel Iris
- Hard_Drive_Capacity: 256 GB SSD
- Monitor/Display Make & Model: 24" Dell Ultrasharp Monitor
- Corel programs: PaintShop Pro, AfterShot Pro
Re: Lens correction supported lenses
Is ASP picking your lens right? I've found that ASP picks the wrong Sigma 10-20 - I've got the f4-5.6 (which is corrected & I would guess is the more common) but ASP seems to always pick the f3.5 (which is in the database but is uncorrected).
Regards
Rick
Regards
Rick
MikeFromMesa
- System_Drive: N/A
- ram: 16 GB
Don't I feel stupid! I have to admit that I did not look carefully at the listed lens. I only saw that it was "uncalibrated". But, as it turns out, you are completely correct. I was using the 4-5.6 but it selected the 3.5.RickHeath wrote:Is ASP picking your lens right? I've found that ASP picks the wrong Sigma 10-20 - I've got the f4-5.6 (which is corrected & I would guess is the more common) but ASP seems to always pick the f3.5 (which is in the database but is uncorrected).
Regards
Rick
Thanks for the speedy reply and the correct information.
No problem - it took me a while to notice here when it picked a wrong but similar lens
In theory you could customise the lens list but I haven't tried it (at least you could previously in Bibble & the format of the files appears similar). A nice little user interface to edit out items that you don't want (cameras & lenses you don't own) would be good to give ASP (& me) less "wrong" choices to make
Regards
Rick.
Regards
Rick.
MikeFromMesa
- System_Drive: N/A
- ram: 16 GB
Thanks. I'm going to give that a try. I will post any information I have about how it works.RickHeath wrote:No problem - it took me a while to notice here when it picked a wrong but similar lens![]()
In theory you could customise the lens list but I haven't tried it (at least you could previously in Bibble & the format of the files appears similar). A nice little user interface to edit out items that you don't want (cameras & lenses you don't own) would be good to give ASP (& me) less "wrong" choices to make![]()
