Topaz Labs plugins can be run from ASP
OldRadioGuy
- motherboard: Dell 0YJPT1 A00
- processor: Intel Core i7-3770 3.40 GHZ 8 virtual cores
- ram: 16 GB
- Video Card: AMD Radeon HD 7770
- sound_card: Realtec High Definition Audio
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung 23" HD 1920x1080 px
In Windows 7 all of the filters produced by Topaz Labs except ReMask can by run directly from AfterShot Pro by using the free utility Topaz Fusion as the editor -- http://www.topazlabs.com/fusion/
For anyone want to test, in Windows, the Fusion EXE file is installed the Common Files folder of Programs.
I assume these plugins will work the same way on the Mac OS, but have no way to test that.
Bob
Bob
Affinity Photo 1.5 | ON1 Photo RAW 2017 | DxO Optics Pro 11 | Aftershot Pro 3 | Olympus PEN-F cameras
Re: Topaz Labs plugins can be run from ASP
Bob - I have Topaz plugins installed with PSP X4, and I just downloaded Fusion and put the file in the Topaz folder under Programs x86 - Common Files. Do I then select the topazfusionexpress.exe file as my external editor (as I think you were saying)? I currently have PSP X4 as my external editor - and it appears I can only have one editor at a time - not both Topaz and PSP X4.
Any help would be appreciated!
Bob
Bob
bananahead
- motherboard: Asus P67
- processor: i7 2600k
- Video Card: Nvidia 650
- sound_card: Asus DX
- Hard_Drive_Capacity: Lots
- Monitor/Display Make & Model: NEC PA272W
I think that you are better off having PSP X4 as your external editor and running any plugins as needed from there.
OldRadioGuy
- ram: 16 GB
In my opinion, this is one of the changes needed in ASP -- ability to assign more than one editor which can then be accessed with shortcut keys. In the meantime, one alternative would be to keep PSPX4 as your external editor, and then select TopazFusionExpress as the open with editor in the batch file that comes up when you do a save Ctrl+S. The assignment sees to be sticky there, thus all you have to do is check or uncheck when a Topaz filter is the only external adjustment needed.bobm185 wrote:Do I then select the topazfusionexpress.exe file as my external editor (as I think you were saying)? I currently have PSP X4 as my external editor - and it appears I can only have one editor at a time - not both Topaz and PSP X4.
Bob
Bob
You know that you can assign an external program to open an image in an output batch & assign a hotkey.
You can have a different program for each batch too. So you could set up several batches (right click in output panel and choose new or duplicate as desired), doing as much or as little processing as you like, and send images to whatever programs you want (using "open with" setting at bottom right of settings window) with whatever you assign as a hotkey (right click on batch and choose "Set shortcut").
Regards
Rick.
Regards
Rick.
OldRadioGuy
- ram: 16 GB
Rick, thanks for this information. Earlier I did a search of the documentation for ASP for assignment of shortcut keys to the batch operation. I either searched incorrectly or the documentation omits that data. Either way, I did not find anything on that topic. I really appreciate your tip.RickHeath wrote:You know that you can assign an external program to open an image in an output batch & assign a hotkey.
Bob
ashmoore
- System_Drive: N/A
- ram: 16G
- Monitor/Display Make & Model: iMac 27"
it sounds like they are being called as an external application rather than actually being a plugin.
I can't visualize how that workflow would work with raws.
It seems like it would only work on jpegs, at which point ASP is out of the workflow.
old Bibble user
Hmm is that (old) Bibble user or (old Bibble) user?
OldRadioGuy
- ram: 16 GB
Ashmoore, it also sounds like we're engaged in a bit of semantics here.ashmoore wrote:it sounds like they are being called as an external application rather than actually being a plugin.
Who cares if they are internal plugins or external plugins as long as they work? And they perform nondestructive editing on RAW, TIF or JPG files when called within ASP.
Bob
bananahead
OldRadioGuy wrote: they perform nondestructive editing on RAW
This they don't do. They need the image in a converted format.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Well, they are significantly different an have a huge impact on the workflow.OldRadioGuy wrote:Who cares if they are internal plugins or external plugins as long as they work? And they perform nondestructive editing on RAW, TIF or JPG files when called within ASP.
Only a true plugin in the AS pipeline can be part of the non destructive image adjustment chain.
Everything that needs an intermediate file will be destructive relative to that file.
That file will also not pick up any changes made in the pipeline after the file was created. It would actually reqiure a complete redoing of all the steps performed in the external program if something was changed on the source file within AS.
So in the end, this is an external edit resulting in an extra file that sits after the AS adjustment, not an an adjustment within the non destructive edit chain of AS.
So please stop mixing that up. It is utterly confusing and gives unwary readers the wrong impression.
The semantics are very important here.
cheers
afx
ashmoore
- System_Drive: N/A
- ram: 16G
thanks afx
these are not plugins at all then.
They are an external application that destructively edits output from ASP
There are many reasons why this is bad :-
1 - you cannot save settings in a preset or defaults
2 - you cannot apply the settings in a layer
3 - any file that is output from Topaz that shows up in ASP will be reprocessed by ASP defaults
Basically calling this method a "plugin" is highly confusing.
Calling external programs is not a plugin, its an external application. Otherwise PSP, Photoshop, Pixelmator or GIMP could all be called plugins.
Clearly they are not.
Real plugins show up on http://www.aftershotpro.com/plugins
old Bibble user
B4b5
It's not just semantics - it's completely incorrect.afx wrote: So please stop mixing that up. It is utterly confusing and gives unwary readers the wrong impression.
cheers
afx
Considering the fact that Corel has other products such as PaintShop that are good tools but place no particular importance on non destructive editing;
we need to hope that in this new environment Non Destructive remains paramount to ASP.
afx
- System_Drive: N/A
It will, it is just some users who did not grasp the concept yet that get this mixed up....B4b5 wrote:Considering the fact that Corel has other products such as PaintShop that are good tools but place no particular importance on non destructive editing;
cheers
afx
claudermilk
[quote="B4b5]we need to hope that in this new environment Non Destructive remains paramount to ASP.[/quote]
Isn't that the entire reason for ASP/Bibble? Without that you may as well be using PSP/PSCSn.
Bibble transplant
MikeFromMesa
- System_Drive: N/A
- processor: 3.0 GHz Intel Core i7
- ram: 16 GB
- Video Card: Intel Iris
- Hard_Drive_Capacity: 256 GB SSD
- Monitor/Display Make & Model: 24" Dell Ultrasharp Monitor
- Corel programs: PaintShop Pro, AfterShot Pro
Isn't that the entire reason for ASP/Bibble? Without that you may as well be using PSP/PSCSn.[/quote][/quote][/quote]claudermilk wrote:[quote="B4b5]we need to hope that in this new environment Non Destructive remains paramount to ASP.
I do not disagree with your statement, but for those of us processing RAW files all editors are non-destructive. We have our original RAW image, which remains unchanged, and the generated sidecars that describe the changes. I generally find that I never made sufficient changes to run out of "undo" calls so as long as I have not closed the editor I can always expect to undo whatever I need to undo and that is true with pretty much all of my editors (PSP X4, CS5, Dxo OP, ASP, etc).
And, if worse comes to worse I can always start over again with my original RAW image.
