Newbie question: Jpeg output quality: 'Normal' vs 'Proof'
auywy
operating_system: Linux
Post by auywy »
System: Linux Mint 64-bit
The official documentation states that when Image Size is set to 'Proof', the image is half-height and half-width of the original.
My question is what happens with the display of the image when I select 'Normal' size output, i.e. - 'Jpeg full size'. It looks very noisy. And I've checked multiple times to ensure that default rendering does not activate any image modifications or enhancements.
Here's what I did:
(1) Make adjustments to RAW file.
(2) Output to jpeg using 'Proof' quality - i.e. 'Jpeg Proof'. Quality: 90%.
(3) Use ASP file navigator to display the jpeg that was produced.
(4) Output the same file to jpeg using 'Normal' quality - i.e. 'Jpeg Full'. Quality: 90%.
(5) Use ASP file navigator to display the jpeg that was produced.
Proof screenshot: https://docs.google.com/open?id=0BxSfVO ... Q3MzUyMjgx
Full screenshot: https://docs.google.com/open?id=0BxSfVO ... A4NGM5YmNi
'Jpeg Full' displays higher noise. Is this normal? Some explanation for this? Not really critical since it's all used for web display anyway which should use a smaller size. But very curious about this.
Re: Newbie question: Jpeg output quality: 'Normal' vs 'Proof
Please do not double post -- it only causes confusion. I have deleted your other post on the same subject.
Gerard2
processor: AMD Athlon II X4 620 2.61GHz
ram: 4GB
Video Card: Ati radeon x1950xtx 512 mb
sound_card: onboard
Monitor/Display Make & Model: Dell FP2007
Post by Gerard2 »
If you view them in an other image viewer, does the same happen? when you view a jpg in ASP, the default sharpening / levels / contrast etc settings are aaplied. If you over sharpen something, its often noisy.
tomsi42
Post by tomsi42 »
A down-scaled image will show less noise than a fullsize one.
Since the proof version is a downscaled version, I think this is what happens here too.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
auywy wrote:The official documentation states that when Image Size is set to 'Proof', the image is half-height and half-width of the original.
Stay away from proof but define your own queue with defined sizes...
Resizing will reduce noise....
Check for noise in 100% view in AS before you generate output.
cheers
afx
auywy
Post by auywy »
Ken Berry wrote:Please do not double post -- it only causes confusion. I have deleted your other post on the same subject.
Noted. Apologies for the confusion.
auywy
Post by auywy »
Gerard2 wrote:If you view them in an other image viewer, does the same happen? when you view a jpg in ASP, the default sharpening / levels / contrast etc settings are aaplied. If you over sharpen something, its often noisy.
I get strange results when I try using different applications.
When the image is viewed in the default Gnome image viewer (EOG), it looks noisy.
When the same image is viewed in gThumb, Gimp or Shotwell, it looks smooth. :shock:
I should mention that I've been shooting RAW+JPEG. ASP displays straight-from-camera JPEGs perfectly fine. It's only the Jpegs that I output from RAW in ASP that exhibit this strange behaviour. As mentioned, the same image that I output from RAW with 'Full' quality renders smooth in gThumb, Gimp and Shotwell, but noisy in EOG and ASP. Something different about the way these applications render Jpeg? Some geeky googling turns out a few threads talking about libjpeg in Linux and how some applications still rely on an old version. Related?
I should also clarify I view everything via the file navigator, and my default (jpeg) rendering options have 'sharpen' unchecked.
And thanks for the replies so far.
afx
System_Drive: N/A
Post by afx »
EOG is junk, it does not understand CM, so I suggest not using it.
But having said that, this is not the issue here. When images are displayed downsampled, the method used for this will have to be taken into account. Every app uses different methods. EOG and AS are both not brilliant in that regard. Taht can amplify noise.
So again, make sure you compare at 100%...
cheers
afx
grubernd
System_Drive: N/A
Post by grubernd »
in short: "Proof" is optimized for speed and dumps quality for that.
it is your choice if you need halfway decent images and you need them fast.
that would be for selection by someone else, contact sheets or anything else
where the general appearance of the image is more important than pixel-level quality.
Bibble since 2004. Aftershot until 2020. From then on darktable.
auywy
Post by auywy »
Thanks to all who replied. I'm switching to using other photo organizer utility to organize the jpegs, and using ASP only for RAW image processing.
