df wrote:For this simple thing try using the Magic Wand tool. You will need to be in the Edit workspace, not adjust or manage.
Select the blue area using RGB value (or whatever method works for the type of thing you're doing).
On the layers palette, click the mask icon (at the bottom) and choose Hide Selection.
This will give you a mask layer that hide the selection. You can now unselect everything and you will still be left with the mask layer.
To modify the mask, use the Air Brush tool (part of the Paint Brush tool) and paint the mask layer black or white, black showing the layer, white hiding it.
I believe masking is the same in Elements.
Hi df, thank you for your reply.
I was hoping to do it just using the pentool, so that I can then easily resize without losing any quality, and also without having to edit more.
I did eventually find this
http://graphicssoft.about.com/od/paints ... bble05.htm
It's exactly what I want. However, it doesn't seem to be working properly for me, but I do know why.
My shape is one that I want symmetrical, so I designed the left side, duplicated it and then flipped it.
I have only 6 layers for it total (3 for the left, 3 for the right).
I would love to be able to merge each "section" together. For example, I have an "A" in there so I would like connect the left send node with the end node on the right and then merge those two (left + right) down to one single vector layer.
I have tried using Edit Mode > Edit > Merge. But that makes my vector vanish, but does not merge the layer at all.
If anyone could help me with this problem of merging + connecting specific vector layers - that would be fantastic, because then I am confident my original problem can be solved from the link i have posted.
Once again, thank you to anyone who is willing to help. It's greatly appreciated.
