Thanks Sean for the work. I installed ASP on my Linuxbox but used it very seldom because of Andrea missing. Now finally I can start to use ASP for all new pics.
However there is one inconvenience I have seen with Andrea as well: If I choose a slide film (e.g. Kodachrome 200) then the 'Print' option disables itsself. This is okay, but each time I move one of the sliders 'Enlarger' or 'Paper' the 'Print' option renables itsself and I see the negative which makes it impossible to check the result of the slider movements.
best regards
Andreas
[plugin] Film Simulator "Nostalgia" (nee Andrea) Released
seanmpuckett
- System_Drive: N/A
Re: [plugin] Film Simulator "Nostalgia" (nee Andrea) Release
acmh: that's expected behaviour. With the Print checkbox off, neither the Enlarger nor Print latitude sliders would have any effect on the final image at all. Rather than have you move a slider and have nothing happen (the software ignores you), the Print checkbox is turned back on in the assumption that you know what you want: to adjust the print.
I create plug-ins for AfterShot Pro! See http://nexi.com/afplugs
Using Nostalgia in a custom named layer, clicking reset will also reset the name of the layer.
Is it normal ?
Is it normal ?
Darktable 3. Bye bye aftershot.
