Got it (free), like it, must buy... thanks.seanmpuckett wrote:Yes, please share your Nostalgia!
http://www.flickr.com/photos/janus_sand ... /lightbox/
Feature.Zarastro wrote:That is, when you deactivate "colour" option on Nostalgia, it continues to operate with the image in a RGB color space instead of converting the image to gray scale. Bug or feature?
I assume he means the curves tool, and on my system Nostalgia loads before curves. I take this to mean that he's trying to use the curves tool to vary the RGB mix before conversion, but of course all he's doing is giving it a post-conversion colour cast.Zarastro wrote:... Thus, if you have changed the color balance of the picture through the histogram tool, this change in color balance is being propagated to Nostalgia after the gray scale conversion, and thus images acquire a color cast.
Thanks. Followed the instructions and it worked as a charm. However, this is different from B5, right? I've converted an image using Andrea and tried to change the color balance in the Color Tab and the image remained B/W - no color casts were visible. It's just like applying different color filters to achieve different levels of B&W.afx wrote: Feature.
AS operates always in RGB, so the result of Nostalgia is always RGB.
Nostalgia sits before curves in the pipeline, so all curve adjustments happen after Nostalgia worked on the image.
No idea I must admit.Zarastro wrote:However, this is different from B5, right?
In your previous post you mentioned the histogram, which I took to be curves. Curves is after Andrea in B5 and so can't preserve B&W. Colour balance is before and so B&W is preserved. As AFX said, the log will tell you the plugin order and so what is before Andrea/Nostalgia and what is after and so what you can use to manipulate the B&W mix and what you can't.Zarastro wrote:However, this is different from B5, right? I've converted an image using Andrea and tried to change the color balance in the Color Tab and the image remained B/W - no color casts were visible.
