I have downloaded the Title Packs but am not sure they have installed. Can you tell me how to install or how to check?
Thank you
Mark
Title PacksX4
mark9422
- motherboard: ASUS P8Z68 DELUXE GEN3 LGA 1155
- processor: Intel Core i7-2600K Sandy Bridge 3.4GHz OC to 4.5
- Video Card: PNY GeForce GTX 560 Ti
- Hard_Drive_Capacity: 1.5 TB
- Monitor/Display Make & Model: Asus HDCP 24"
Re: Title PacksX4
They should have self installed when you downloaded them - but you can check.
open the Corel Guide by clicking on the orange button with down pointing arrow in the top right corner of VideoStudio - when the guide opens click on the "Do More" tab - then choose 'TITLES' - under each title pack it will either say 'Download now' or 'Installed' - if the later they are installed.
mark9422
Re: Title PacksX4
will they just appear in the tile section?
Re: Title PacksX4
Yes - when you click on the 'T' to open the title library pane you should see them in there.
Re: Title PacksX4
I'm having the exact same problem. I am using Ultimate. I was in the Titles section and selected Get More Content. I then downloaded and "installed" Title Packs 5 & 6. No new Titles appeared outside of the ones that were already there. So I restarted. Same thing. I have no idea where the titles are for Title Packs 5 & 6. If I go back to Get More Content, it says "Installed".
mark9422
Re: Title PacksX4
Despite the kind responses from those viewing here, I too continue to search for this "extra" (installed) content. I haven't seen anything new. Any other help "out there" ?
Thank you in advance!
Re: Title PacksX4
The download files seem to be called Domore_title 0#.exe (#=pack number) when I do a search on my computer I find them in :-
C:\ProgramData\Corel\Downloads\540244232_410003\1298540422290 / - - various sub-folders
after I have installed them they modify a file called VS_title.dat in the the following folder :-
C:\Users\*Username*\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro\14.0\en-US\UpdateGallery
When you downloaded and installed did you then allow windows to install as well - I just downloaded one more set and I had to click either install or 'yes' about 7 times in all - try running the .exe but keep clicking install/yes until you get a message to the effect "the content will be available to you next time you start VS"
mark9422
Re: Title PacksX4
Thanks! I'll give it a go and report back!
Re: Title PacksX4
Each time you install a Title Pack the title library should increase by 10.
There is a post referring to Templates and Titles
http://forum.corel.com/EN/viewtopic.php ... &p#p225920
