Aftershot keyword bug?
goatbeater
Post by goatbeater »
I'm a long term user and fan of PSP - since the JASC days.
I wanted to improve workflow and thought I'd move to Adobe products.
Tried Lightroom - even paid the money - and find it unhelpful at best and unworkable most of the time.
So I decided that Aftershot should be OK - Corel product etc ...
Still have the trial but the jury's out right now - how come workflow products are SO complex and SO damn SLOW!!!
Anyway - I added my 50k photos and started to keyword.
Of course I made some mistakes.
The problem is I have some under sets like Subject/People/Family or Genre/Snapshot that are mistakes and I can't get rid of them.
They don't appear on the right hand side in metadata but the images turn up in the collections when selected on the left hand side.
Is this an old/new bug?
It's really causing grief cos I need to get this indexing done or find something else to use
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Re: Aftershot keyword bug?
Post by ogrizzo »
Bibble 5 has always shown, now and then, this bug. The best way to correct it is to remove from catalogue the offending images and to reimport them (it's quite fast since ASP won't reimport what is already in the catalogue).
ChrisC
motherboard: Intel HM65
processor: Intel Core i7
ram: 8 GB DDR3
Video Card: AMD Radeon HD6770M
sound_card: Beats Soundsystem
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
Post by ChrisC »
I also had this problem in the past and recoverd by creating a completely new catalogue which took quite a while (Bibble XMPs should exist).
Maybe a little bit stupid but:"how can one remove a single image from a catalogue?" (never realised that this is possible) :?
ogrizzo
System_Drive: Q
ram: 8 GB
Post by ogrizzo »
ChrisC wrote:I also had this problem in the past and recoverd by creating a completely new catalogue which took quite a while (Bibble XMPs should exist).
Take note of the folder where the picture lives: Edit|Version|Show master file location
Most often, you'll have many pictures in the same folder showing the same problem; it could be useful to select 'Link to Catalogs' in the Metadata Browser.
If you did not allow ASP to create .xmp files (which you should), write them for your files before removing them.
Remove the picture: Edit|Version|Remove Version
Don't select 'Move master file to trash', of course
Reimport the folder, or just those pictures using drag'n'drop (this would open a queue). Even if the rogue metadata are still there, you usually can remove them at this point. If that doesn't work, you will have to edit by hand the xmp file.
You will lose history on those pictures, of course; but it's still much faster than reimporting the whole catalog.
Ottavio
andreas
operating_system: Linux
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Post by andreas »
also you may try from the menu when one of these images is selected:
- save standard xmp for the version
- merge with external metadata
Please give us an info
- if thats works
- perhaps you can give a hint how to get in this situation
There was a keyword bug in b5 which was solved in the latest b5 version and also in ASP. Maybe there is one deeper left...
Andreas
Linux - not Windows
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
ogrizzo wrote:Don't select 'Move master file to trash', of course
:oops: so obvious - thanks
goatbeater
andreas
WOW - I'm impressed by this forum...
I posted then went to bed - got up and there were replies, at least 2 looked promising.
I tried andreas's approach on one example and it worked, so I tried on a Genre: Snapshot that had also crept in somehow - no luck so far! :(
I'd obviously prefer not to remove images and re-catalogue as this becomes less workable as time goes on.
I'll post with any updates...
...and thanks to everybody for the replies
goatbeater
andreas
darn posted too soon ....
When I got back to Aftershot I noticed that the Genre: Snapshot had appeared in the keyword lists in red.
This had not appeared before either with one or several images selected!
So ... I removed it from the list and Voila! it disappeared and the entry disappeared from the list at bottom right!
So andreas is spot on and this is a workable solution even with tens of thousands of images.
AF still takes a while to process but at least it's AF doing the thinking and the work, not me!
Thanks andreas!
What a cool forum :) :) :)
I3ilbo
ram: 4GB
Video Card: Nvidia 8600GT
Post by I3ilbo »
isn't it time to remove this bug? This bug is known for years and makes catalogs nearly unusable
please resolve this bug in ASP!!!!!!
bos
System_Drive: Z
Post by bos »
andreas wrote: - save standard xmp for the version
I tried this and other suggestions (removing and reimporting), but they didn't always work. Sometimes they even created more problems like, adding additional keywords that weren't in the xmp files (they were embedded in the image since who knows when).
In the end I just created a keyword set with the same hierarchy as the troubled one. Selected all the images and removed the keyword set from selection. The funny thing is that it didn't remove the keywords from the whole selection at once, I had to preform the remove action multiple times and each time it removed the keywords from a random number of images.
It's really time-consuming creating all this keyword sets just so I could get around this bug. In general I find it really hard to remove or add one keyword that is common to a group of images, without breaking all the other keywords.
Does anybody have tips about keywords organization, so to avoid running into this bug every 10 minutes when working with keywords hierarchy?
marbly
Post by marbly »
lazyknight
System_Drive: N/A
Post by lazyknight »
Just had exactly this problem -- to the best of my knowledge, here's a repro:
* Add a keyword to a set of photos e.g. "Location; Egyp; Red Sea,
* Add another keyword in the same hierarchy to a subset of the photos: e.g. "Location; Egyp; Sharm El Sheikh"
* Select all "Location; Egyp" photos in the metadata browser
* Correct the "Location; Egypt; Red Sea" typo, but not the other, and apply.
* Correct the other typo keyword...
... and see the second one remain in the metadata browser, linked to the same photos. The correct spelling will show up in the Keywords panel in the right panel though.
The fix from this thread fixed -- forced .xmp creation, removed version from catalogue, re-imported -- but this is a rather annoying little bug...
