Colored "frames" bug with CA correction
komtur
When I use Chromatic Aberration Correcton on any RAW file, everything goes fine in ASP, but the resulting file (TIFF) saved on disk has ugly red / green thin borders (especially at the left side of image).
I wonder if there is any way to avoid this problem temporary.
rawshoter
- processor: Dualcore
- ram: 4 GB
- Video Card: ATI - 1GB
Re: Colored "frames" bug with CA correction
I to have those 1 pixel wide red lines at the image edges.
And in addition, on my images there are vertical and horizontal lines across the entire image.
They only appear when the CA correction is in use. And thy are visible in ASP as well as on the exported Jpeg file.
Rob Greenstein
- motherboard: ASUSTek Computer INC. LITHIUM 1.04
- processor: 3.00 GHz Intel Pentium D
- ram: 4GB
- Video Card: ATI Radeon X300_X550_X1050 Series
- sound_card: Hauppauge WinTV PVR PCI II [26xxx]
- Hard_Drive_Capacity: 2.135TB
- Monitor/Display Make & Model: HP f2105
Is the on screen image (revealing the vertical and horizontal fracture lines) being viewed at 1:1 100%?
Are the same artifacts also present in any generated TIFF and JPG output files?
Robert S. Greenstein, Esq.
Entertainment Industry Business & Legal Affairs
Greenstein Law Offices, Woodland Hills, CA USA
● AfterShot Pro & PaintShop Pro X4 Ultimate
● Canon EOS-1D Mark II N
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
komtur
In my case, when I'm looking at the image in ASP, everything is OK - no lines, no colored borders.Rob Greenstein wrote:Is the on screen image (revealing the vertical and horizontal fracture lines) being viewed at 1:1 100%?
I have these artifacts (lines and borders) only in generatedt TIFFs and JPEGs.
rawshoter
- ram: 4 GB
Yes and they are only visible at 1:1.Rob Greenstein wrote:Is the on screen image (revealing the vertical and horizontal fracture lines) being viewed at 1:1 100%?
Yes they are, though they are not always easy to find. And it strongly depends on the content of the image. You can´t find them on a pure blue sky for instance. But it´s not file type related because you can see them already in ASP.Are the same artifacts also present in any generated TIFF and JPG output files?
Well, what I found out so far.
There are always two lines crossing the image right from the center. To find them, you need to set the ASP sharpening at minimum 200 better 300 or more and one of the CA correction channels at some value other than zero. (I set R/C to +0,030 ). Any denoising must be set off, because it makes it harder to find the artifacts.
Now find the center of the image and beginning from there, go to left, right, up and down, and look for the offset line/artifacts. It is helpful if you place a grid line in your image editor near the center of the image and oversharpen the image a little bit, to boost the phenomenon.
At this way, I could find the artifacts on Nikon D5100, Canon EOS 5D and on Powershot G10 files.
I guess, that for the CA correction, ASP divides the image into 4 parts and shift them against each other to get the color offset back on track. The resulting misalignment of this 4 blocks causes the artifacts. But again, this is just my humble guess.
tomsi42
Does the frames disappear if you turn of the native ASP sharpening?
rawshoter
- ram: 4 GB
I think we have to distinguish between two different phenomenons occuring by the CA correction.tomsi42 wrote:Does the frames disappear if you turn of the native ASP sharpening?
One are the colored lines at the edges of the image described by komtur. I observed them to on some of my images, but can´t reproduce them reliably.
And the other one are the 2 artifact lines crossing the center of the image.
This one doesn´t disappear if I turn of the sharpening. But they obviously become less visible because of the blurring effect.
Can you, or someone else, reproduce this?
tomsi42
I see.rawshoter wrote: I think we have to distinguish between two different phenomenons occuring by the CA correction.
I hadn't heard about this one.rawshoter wrote: One are the colored lines at the edges of the image described by komtur. I observed them to on some of my images, but can´t reproduce them reliably.
I have heard about this one, but haven't seen it myself. It's not only CA that can cause this, apparently. Other tools might also provoke this.rawshoter wrote: And the other one are the 2 artifact lines crossing the center of the image.
I can see if I am able to try this tonigh. I have files from multiple Canon, Nikon, Olympus and Panasonic cameras, so it should be possible to gather some useful information here.rawshoter wrote: Can you, or someone else, reproduce this?
rawshoter
- ram: 4 GB
Here is an example of that. The red line is located at the upper edge, it is 1 pixel wide and goes over the entire image. I blew up the screenshot to 300% to make it more visible.tomsi42 wrote:rawshoter wrote: One are the colored lines at the edges of the image described by komtur. I observed them to on some of my images, but can´t reproduce them reliably.
In opposition to the artifacts bug, this edge or frame lines are only visible at the output files.
In the meantime I got feedback on a german forum where someone could reproduce that on his Linux machine with a D90 file.tomsi42 wrote: I can see if I am able to try this tonigh. I have files from multiple Canon, Nikon, Olympus and Panasonic cameras, so it should be possible to gather some useful information here.
tomsi42
Is it also visible when you do a crop?rawshoter wrote: Here is an example of that.
-- 8< --
Ok. I still think I will have a little look.rawshoter wrote: In the meantime I got feedback on a german forum where someone could reproduce that on his Linux machine with a D90 file.
rawshoter
- ram: 4 GB
No, then it´s vanished.tomsi42 wrote: Is it also visible when you do a crop?
Oh yes please. I don´t meant that further testing is not necessary.Ok. I still think I will have a little look.
tomsi42
Then it should be easy to reproduce and fix. I suspect the CA algorythm expands the canvas to enable the bitshifting needed, but forgets to crop afterwards.rawshoter wrote:No, then it´s vanished.tomsi42 wrote: Is it also visible when you do a crop?
And that also explains why it's not always seen - if you straigthen you photo, a crop is applied. And if you crop yourself, it will be gone on at least one side. Lens correction will also apply a crop.
spoilerhead
- System_Drive: N/A
- Hard_Drive_Capacity: 13.5TB
i can reproduce it with crop on
looks like it is exactly in the center of the original image.
my ASP Plugins - donation button ( send beer!
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
tomsi42
The problem is that we are discussing two bugs in this thread...spoilerhead wrote:i can reproduce it with crop on![]()
And the bug, which you are thinking about, is not fixed by doing a crop. We are talking about the other one...
rawshoter
- ram: 4 GB
Are you sure?tomsi42 wrote:Lens correction will also apply a crop.
If I do only CA correction, then the red line goes continuous from one corner to the other.
But if I additionally apply lens correction, where the corners are being pushed outside the canvas, then the red line only remains in the middle part of the image because the rest is just pushed out by the lens correction. So it depends on the amount and method of lens correction, whether the line completely disappears or not.
