"Convert Step got some problems ! (4570)
Report ID : 0x800411da(4570)"
I get this message during the rendering process prior to burning. please help me with some type of solution!!!! that would be amazing
please email : michaeljlrobinson@gmail.com
Help Please!! Problems during rendering before Burning...
aab394
This error seems to be related to MP3 files used with a DVD SlideShow. MF has a default setting for the MP3 files, which is probably different than the MP3 files you are using.
Here is how you can change the settings :
Project Settings
Change MPEG settings
Customize
Compression
Choose MPEG Audio in Audio Format
Choose the Audio bit rate that matches your MP3 files
Project Settings
Customize
Compression
bardo
Thanks for that last response. That worked for me as I had the same problem. I was using one of the MovieFactory 4 .mpa music files with my title screen and it kept failing. I wasn't sure of the audio bit rate (properties doesn't seem to show it) but I let it default and it seemed to work OK after that.
jeramiah
Didn't work for me...
Didn't work for me, I'm still getting the error "Unspecified error. Report ID: 0x8004125f(4703). I even rendered the mp3 to exactly 192kbs that way I could specifiy under the custom settings that I was in fact using 192kbs. Still giving me the error message. Anything else I could try?
jeramiah
Still getting error even without background sound
Always stops around 15 seconds inot Converting video title and gives me that error. So, I tried unchecking the motion menu. Still got an error. So I tried no background sound at all, still got the same error. This leads me to believe that it has nothign to do at all with the audio or video settings of the menu.
