i put it in the "Stuff" section, cause i dont need it.. same with the Color Correction.. before you start asking about that, too, and it gets really embarrassing - helping is one thing, but a little effort on the receiving side like reading and trying to comprehend goes a long way in making you look better.TexJoachim wrote:Öhm, the "Mirror / Invert" thingie is missing now.
Any way to find it?
Joachim
customToolsUI.txt
Re: customToolsUI.txt
Bibble since 2004. Aftershot until 2020. From then on darktable.
TexJoachim
- System_Drive: Z
No must have missed that. Thx for the hint (taken) and info!
Joachim
Joachim
derouyag
- processor: Intel Core2 Quad CPU Q6700 2.66GHz
- Video Card: NVidia GeForce 8800 GT
- Hard_Drive_Capacity: 11TB
- Monitor/Display Make & Model: HP w2408h (Dual)
Newbie Info Bite
Without wasting too much of everyones time, I did go through all that I read here and found a newbie info bite missing.
All of the ASP Basic UI files can be found in the "C:\Program Files (x86)\Corel\Corel AfterShot Pro\supportfiles\tools" directory. When trying to address UI files in the sub-directories the original author uses the "directory name" + "/" + "UI file."
E.g.
Direct from the Tools directory: Standard, Std, BasicTools.ui
From the Tools\Advanced directory: Color, Clr, Advanced/Curves.ui
Plugins are done directly, but can be found at: C:\Users\User\AppData\Local\Corel\AfterShot Pro\Plugins. The Plugin portion is case sensitive and can be found in the Info.afpxml file, specifically the indentifier="...."
E.g. Long Tab Name, Short Tab Name, Plugin
Effects, Efts, tin.tin.zBlur
Hope this helps the newbies like me.
E.g.
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
As afx said, it can be done, up to a point. The idea is that you take a copy of the ui file with the tools you want to duplicate, edit it so that it's only got the bits you want (this is the tricky bit), and then you "attach" it to another plugin. These tools will then appear as a separate panel above or below the other plugin. It's not perfect flexibility, but it does provide an alternative to pinning tool panels if you want to avoid tab switching all the time. I can provide instructions and an example if there is interest.afx wrote:No, you can not split up a tool, you can only use the tools as defined (unless you start Qt UI files hacking).Tadjio wrote:Does anyone know if it is possible to split out all the "Standard" functions into separate items in other tabs?
F_P
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Yes please, I did have a peek before but chickened out. I'm not yet familiar enough with ASP to know what I really want!ferdinand-paris wrote:As afx said, it can be done, up to a point. The idea is that you take a copy of the ui file with the tools you want to duplicate, edit it so that it's only got the bits you want (this is the tricky bit), and then you "attach" it to another plugin. These tools will then appear as a separate panel above or below the other plugin. It's not perfect flexibility, but it does provide an alternative to pinning tool panels if you want to avoid tab switching all the time. I can provide instructions and an example if there is interest.afx wrote:No, you can not split up a tool, you can only use the tools as defined (unless you start Qt UI files hacking).Tadjio wrote:Does anyone know if it is possible to split out all the "Standard" functions into separate items in other tabs?
F_P
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
lundbech
- System_Drive: N/A
- motherboard: HAL 9000
Re: Newbie Info Bite
The identifier for each plugin can also be found in the menus: Help -> System Infoderouyag wrote: Plugins are done directly, but can be found at: C:\Users\User\AppData\Local\Corel\AfterShot Pro\Plugins. The Plugin portion is case sensitive and can be found in the Info.afpxml file, specifically the indentifier="...."
ferdinand-paris
- ram: 4Gb
Well, I can only give so much detail. In what follows I am assuming that you want the Temp, Straighten and Vibrance tools in a tab just above Bez. I also use the customtoolsui.txt file to position to exposure panel just above Bez, so I have a layout like the attached file.Tadjio wrote:Yes please, I did have a peek before but chickened out. I'm not yet familiar enough with ASP to know what I really want!
1. Find the BasicTools.ui file in C:\Program Files\Corel\Corel AfterShot Pro\supportfiles\tools (or the equivalent location for your OS).
2. Take a copy and place it in [User Folder Location]\Plugins\Bez.afplugin\ui and rename it BasicTools-bez.ui for the sake of clarity.
3. Edit the file and delete or comment out the bits that you don't want. I suspect this is the bit that you found to be too hard. Truth is, it's a bit complex to describe here - you have to understand the structure of the file in order to do this. Or use Qt Designer. To make it easy, I have put the edited file on my server at http://www.ferdinand-paris.com/bibble/B ... ls-bez.zip which has all the unwanted bits commented out. [Note: if you open this in Qt Designer it will strip all the comments out, so don't do that.]
4. Edit the Info.afpxml file in [User Folder Location]\Plugins\Bez.afplugin and before the line
Code: Select all
<li>ui/Bez.ui</li>Code: Select all
<li>ui/BasicTools-bez.ui</li>F_P
Tadjio
- sound_card: Sound
That worked a treat, thanks very much Ferdinand.ferdinand-paris wrote:Well, I can only give so much detail...Tadjio wrote:Yes please, I did have a peek before but chickened out. I'm not yet familiar enough with ASP to know what I really want!
A crash course in XML editing, how to put in comments with dates, remembering to copy everything I touched, testing step by step.
Tadjio
