customToolsUI.txt
B4b5
Re: customToolsUI.txt
Post by B4b5 »
MarkZ wrote:More, M, sph.Vigne
More, M, sph.zPerspector
# ----- stuff i am not interested in, goes into the last tab
Stuff, S, SelectiveColor/SelectiveColorWidget.ui
Stuff, S, MirrorInvert.ui[/code]
- under Metadata I get a menu item called "Form" (see below) with a Manager selection at the bottom that does not work. I don't see "Form" anywhere in the file, Tools or Plugins. Where does this come from, what is its function?
- Even though I included Vigne and zPerspector under More, they appear under "Plugins 1" in the tabs. Grain and Presets appear in the More tab.
Any ideas?
Mark
You've got the identifiers wrong...
tin.tin.zPerspector
com.kbarni.vigne
claudermilk
Post by claudermilk »
Remember to go into the Help/About dialog to see the proper identifiers for your plugins.
Bibble transplant
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
B4b5 wrote: You've got the identifiers wrong...
tin.tin.zPerspector
com.kbarni.vigne
Thanks B4b5 - the identifier for zPerspector worked but not the one for Vigne.
claudermilk wrote:Remember to go into the Help/About dialog to see the proper identifiers for your plugins.
Claudermilk - I couldn't find any obvious Help/About for the plugins but after looking around I found a "Flight of the Bibbles" page posted by afx about plugins which led me to the Info.afpxml file for Vigne. There I found that the correct identifier is now com.Corel. The plugins are in their tabs now. :)
Afx, didn't see your earlier note on the previous page when I wrote this - now I see where the identifiers are in the Help/System info, but in the meantime I learned some more about the files.
Mark
Mark
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
MarkZ wrote:I couldn't find any obvious Help/About for the plugins
If you go into Help > System Info... and then scroll down you will find a list of Plugins.
Most of mine are in <User Home>/Plugins but one (B&W) is in <System Home>/Plugins.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
claudermilk
Yes, System Info is what I meant. For all the add-on plugins, all you need is the ID. The blog posting is a good start and has most of the built-in tools defined that you can simply copy/paste.
Bibble transplant
wongjai888
operating_system: Windows 8.1
Post by wongjai888 »
I'm new to fiddling with the UI and was able to easily use the examples provided above.
Many many thanks to you all for sharing!!
TexJoachim
operating_system: Linux
System_Drive: Z
Post by TexJoachim »
I'd just like to rearrange the plugins, but keep the original tools where they normally are. Now, when I ust this customToolsUI.txt, all the normal tools won't show up. What do I have to add to preserve the original tools in their original order?
Joachim
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
TexJoachim wrote: What do I have to add to preserve the original tools in their original order?
List them in their original order....
cheers
afx
TexJoachim
System_Drive: Z
And how do I find out the names?
Joachim
Tadjio
sound_card: Sound
Post by Tadjio »
TexJoachim wrote:And how do I find out the names?
Joachim
Someone posted a starter shell of CustomToolUI which reproduces the ASP defaults but I am afraid I can't remember who!
Tadjio
grubernd
System_Drive: N/A
Post by grubernd »
Joachim
try the first post. :D
Bibble since 2004. Aftershot until 2020. From then on darktable.
TexJoachim
System_Drive: Z
Thanks!
Joachim
Tadjio
sound_card: Sound
Post by Tadjio »
grubernd wrote:
Joachim
Over a fortnight ago - seems like a lifetime in ASP learning terms :oops:
Tadjio
TexJoachim
System_Drive: Z
Öhm, the "Mirror / Invert" thingie is missing now.
Any way to find it?
Joachim
afx
System_Drive: N/A
Post by afx »
TexJoachim wrote:Öhm, the "Mirror / Invert" thingie is missing now.
Any way to find it?
Did you ever read the original blog post?
Instructions on how to find the original tools where posted there.
Anyway, MirrorInvert.ui is what you are looking for.
cheers
afx
