I have a problem with VS X3 due to the fact that the burner crashes. I have made some DVDs with it previously. I have loaded VS X4 trial version and that will burn the DVD. I do not feel that I should buy the new version just to get the burner. The error message is:
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: BurningApp.exe
Application Version: 1.0.0.50
Application Timestamp: 4b293ba0
Fault Module Name: uipp.dll
Fault Module Version: 0.9.0.0
Fault Module Timestamp: 4b294490
Exception Code: c0000005
Exception Offset: 00271b1f
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 3081
which means nothing to me.
What should my next step be?
Many thanks,
Robin Chapple
VS X3 Burner crashes
Re: VS X3 Burner crashes
When you say the burner in X3 - X3 does not have a burn module - so you are directed to another programme - but which one - did you take up the free MovieFactory offer ??
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Just like what Brian mention VS X3 does not have an internal burning module, you will need to either use DVD Factory Pro 2010 or the DVD MovieFactory 7 Se which you need separately. It will be installed when you install the VS X3 SP1.
Here's a good KB on how to burn a disc using VS X3 - http://corel.force.com/index/articles/e ... actory-7SE
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
