mpgmux.dll/stackhash errors
markguitre
motherboard: Quanta
processor: 2.3 Gigahertz 3rd Generation Intel Core i7-3630QM
ram: 12GB
Video Card: NVIDIA GeForce GT 630M
Hard_Drive_Capacity: 750GB
Post by markguitre »
Only recently, when burning 50gb Blueray discs (either -R or -RE) the program crashes due to a mpgmux.dll error.
This always happens between 5% and 8% of the video multiplexing stage. I have version 1.1.6.15 of this dll file.
The files in the project are all imported from DVD+RW discs I made some years ago.
Now it has begun happening even when I use 25gb Blueray discs...I am using MF6 HD Plus. How to solve this?
Problem Event Name: APPCRASH
Application Name: DVDMF.exe
Application Version: 6.0.0.0
Application Timestamp: 4694bcdc
Fault Module Name: mpgmux.dll
Fault Module Version: 1.1.6.15
Fault Module Timestamp: 4bf0c174
Exception Code: c0000005
Exception Offset: 000264f6
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
And now this, when I try to open any other project:
Problem Event Name: BEX
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0d51ef5f
Exception Data: badc0de1
Locale ID: 1033
Because of these two errors, MF6+ is now 'rendered' totally useless.
Registry cleaning? Reinstall entire program?
Anyone can help??
Mark Lis
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: mpgmux.dll/stackhash errors
Post by teknisyan »
If you've been able to burn BD before then one of the program or updates that you or Windows (auto-update) installed caused conflict with DMF 6. You may want to check the paper-trial and see what are the programs or updates that where installed from the time it was working and from the time it started to act weird. You may also want to update your DMF 6, you can download all updates at http://www.corel.com/corel/pages/index. ... id=1300001
Also... officially DMF 6 is not compatible with Windows 7 "http://www.corel.com/corel/pages/index.jsp?pgid=800577" so this can be one of the problem caused by incompatibility of DMF 6 with Windows 7.
There is a workaround for you to make old program works on Windows 7, however we cannot assure you this is a 100% fool proof. You can use the Windows 7 Program Compatibility which are both from Microsoft.
You can follow the steps for Windows 7 Program Compatibility from this link: http://windows.microsoft.com/en-US/wind ... of-Windows
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
markguitre
motherboard: Quanta
ram: 12GB
After replacing MF6 with MF7 Pro, the "stackhash" and "mpgmux.dll" errors have
disappeared. The problems in MF 6 were unrelated to new programs, updates or system changes,
since none were added or made. The computer is kept mostly offline and used solely
for video editing. However, I think I have identified a certain file type in my project
which causes trouble, no matter which MF I use.
In MF7 Pro, I now encounter an "H264vDec.dll" crash some, but
not all of the time. I suspect the troublesome files are ones I imported off discs I made
in a stand alone DVD recorder--discs in the "DVD+VR" mode. When I try
to burn a Blueray disc with these files, the errors and crashes occur, all the more
when I use the +VR files together with .m2ts files (from an AVCHD camcorder).
When I remove all the DVD+VR files, the errors and crashes are gone.
In sum, to burn a Blueray disc with all .m2ts files poses no problem.
And the DVD+VR files can be burned to a DVD with no problem.
But try to burn DVD+VR files to a Blueray disc, whether in MF 6 or 7, and you will have Big Problems.
(The purpose of the project is to save space: trading 9 or 10 DVD+VR discs
for just one 50gb Blueray.)
Mark Lis
