Dulling down a sunny landscape?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
Odd sort of requirement I suppose, but using PaintShop Pro 8 does anyone know of a script or technique that would:
- Replace a clear blue sky with a grey one
- Generally 'dull down' the greenery
- Take the edge of the sunny brightness of any roads or paths
In short, make a sunny day in the country look like a greyish one?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Dulling down a sunny landscape?
Post by LeviFiction »
You could lower the saturation using the Hue/Saturation/Lightness command. That tends to grey things out.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
I'd also lower the contrast as well, that dulls things up quite a bit. Actually most "sharpening" routines are actually contrast adjustments from what I've read in various forums.
Regards, Dan
wds937
motherboard: Dell 0HN7XN A01
processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
ram: 4 GB
Video Card: Intel G41 Express - integrated
sound_card: Realtek High Definition Audio - integrated
Hard_Drive_Capacity: 320 GB
Monitor/Display Make & Model: ASUS VS247
Post by wds937 »
terrypin wrote:Odd sort of requirement I suppose, but using PaintShop Pro 8 does anyone know of a script or technique that would:
There are many ways you can approach this. I'll suggest two approaches, one easier and the other less easy (but more flexible). The actual values you use will depend upon the particular image you are editing and just how dull or gray you want the final result. Note that these steps are for PSP 8; later versions will have additional tools available and some minor differences, but the concepts should still apply.
The first approach uses the Aged Newspaper effect.
  1. Layers > Duplicate
  2. Be sure the new layer is highlighted in the Layers palette
  3. Selections > Select All
  4. Effects > Artistic Effects > Aged Newspaper...; use 10 for Amount to age
  5. Selections > Select None
  6. Right-click the new layer in the Layers palette; choose Properties; use 70 for Opacity
The second approach will tackle, in order, the sky (Steps 1 through 3), the greenery (Steps 4 through 8), the sunny brightness (Step 9), and overall color saturation (Steps 10 through 15).
  1. Select the sky. Use the Magic Wand tool, with Mode=Add, Match mode=Color, and Tolerance=20. This may require multiple clicks. If any click causes the selection to include anything other than the sky, click Undo, then reselect using a smaller Tolerance value.
  2. Adjust > Hue and Saturation > Hue/Saturation/Lightness...; use -70 for Saturation and -20 for Lightness
  3. Selections > Select None
  4. Select the greenery. Use the Magic Wand with similar settings and a similar approach to what was used for selecting the sky.
  5. Adjust > Brightness and Contrast > Gamma Correction...; be sure the Link checkbox is checked, and use 0.8 as the correction value
  6. Adjust > Brightness and Contrast > Brightness/Contrast...; use 0 for Brightness and -20 for Contrast
  7. Adjust > Color Balance > Manual Color Correction...; locate a representative, bright color of greenery; left-click and then right-click this location on the image, to set the Source and Target values; note the value displayed for Saturation, and reduce it by half
  8. Selections > Select None
  9. Adjust > Brightness and Contrast > Curves...; select RGB for Channel; drag the upper-right corner of the graph so that Input is 255 and Output is 235
  10. Layers > Duplicate
  11. Be sure the new layer is highlighted in the Layers palette
  12. Selections > Select All
  13. Adjust > Hue and Saturation > Hue/Saturation/Lightness...; use -100 for Saturation and 0 for Lightness
  14. Selections > Select None
  15. Right-click the new layer in the Layers palette; choose Properties; use 20 for Opacity
Use these steps as suggestions and guidelines, rather than as an exact procedure. As you choose specific values, observe the actual changes in the image, and re-adjust accordingly. It is also likely that some of these steps will give you other ideas.
