AfterShot Pro High Pass Sharpen [and Wavelet Sharpen Plugin]
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
One feature of PaintShop Pro that I use all the time is High Pass Sharpen.
In particular I do a fine sharpening with a radius of 0.5 (with Stremgth 100% and Blend Mode 'Hard Light')
Is it possible to do the same in AfterShot Pro?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: AfterShot Pro High Pass Sharpen
Grab the Wavelet Sharpen Plugin.
Beats all those USM tricks any time (but has USM if needed)
cheers
afx
cheers
afx
Tadjio
- sound_card: Sound
Thanks.afx wrote:Grab the Wavelet Sharpen Plugin.
Is this available for ASP now?
Tadjio
spoilerhead
- System_Drive: N/A
- Hard_Drive_Capacity: 13.5TB
right at http://aftershotpro.com/plugins/index.h ... etsharpen3Tadjio wrote:Is this available for ASP now?
my ASP Plugins - donation button ( send beer!
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
Tadjio
- sound_card: Sound
That looks great.spoilerhead wrote:right at http://aftershotpro.com/plugins/index.h ... etsharpen3
Can you tell me, can I achieve the same effect as I do with PSP HPS Radius 0.5 as I described above?
Tadjio
Tadjio
- sound_card: Sound
OK, I have installed the plug-in, thanks very much.spoilerhead wrote:right at http://aftershotpro.com/plugins/index.h ... etsharpen3
(Incidentally it knocked my 'Toggle Orientation' (Ctrl+L) from Vertical to Horizontal - took a while to find how to reset it
Are there any instructions / explanation / user manual for all the features?
What are Wavelet1 and Wavelet2? Are they some form of presets?
When might you use them as opposed to Gradient or USM?
What's Clarity Mode and Microcontrast?
And 'Deprecated'? Why two Salt+Pepper boxes?
I followed the tooltip prompts but "with of the Gradient (slow)" stumped me!
Sorry for so many questions...
Tadjio
andysalay
- System_Drive: Z
- motherboard: ASUS P5E WS PRO
- processor: Core2 Quad Q6700
- Video Card: AMD Radeon HD 6670
I am quoting Spoilerhead from one of his posts in Bibble5 forum:
Bibble5 forums are full of gems.
And they are well categorised. I was able to find it without search engine, in very short time.
Andy Salay
And maybe you find attachment of the first post of this thread most valueable.spoilerhead wrote:the "manual" can be summarised in just some sentences:
* use USM for local contrast control, "Clarity" will emulate the bevarior of a well known product. don't use usm for general purpose sharpening, sharpen1/2 will give much better results
* use sharpen1 and sharpen2 for detail sharpening, if just sharpen1 isn't enough use sharpen2 with a larger radius
* turn off bibble sharpening it you use sharpen1/2
* use gradient sharpen only if you need it. it can be helpful against the anti-aliasing blur certain sensors produce, usually its enough if you find a setting that "just works" and save it as a preset
* gradient sharpening is slow.
* find settings that work for your camera(s) and store them as presets/default. i find myself using the same sharpening settings over and over again
*play with the sliders to get a feel about what the plugin can do
* all rules are meant to be broken
Andy Salay
Tadjio
- sound_card: Sound
Thanks a lot Andy - lots to read and study. I've downloaded the pdf and studied the 'famous' flowcharts but I'm not sure I will plough through all 23 pages of the thread!andysalay wrote:I am quoting Spoilerhead from one of his posts in Bibble5 forum:And maybe you find attachment of the first post of this thread most valueable.spoilerhead wrote:the "manual" can be summarised in just some sentences:
Bibble5 forums are full of gems.And they are well categorised. I was able to find it without search engine, in very short time.
Andy Salay
Tadjio
spoilerhead
- System_Drive: N/A
nobody found that typo in width for a year or so, i guess that means nobody reads the mouseovers anyways
Yes, a real manual is missing, but honestly, the old "learning by doing" applies. As every camera is different, a reciepe that works well for camera a might not work well for camera b, so best is just to play with it until you found some settings you like, and create a preset
Tadjio
- sound_card: Sound
Thanks, spoilerhead, I took your advice and had a play tonight.spoilerhead wrote:but honestly, the old "learning by doing" applies. As every camera is different, a reciepe that works well for camera a might not work well for camera b, so best is just to play with it until you found some settings you like, and create a preset
The trouble is, there are so many variables and options one could play for ever but it does seem very useful.
I'm using RAW+JPEG Canon Images, so my JPGs have the Standard Picture Style Sharpening whereas my CR2 files don't.
I'm new to Bibble/ASP - I have just found how to save a preset but can I amend the 'default' settings without a preset?
Tadjio
afx
- System_Drive: N/A
All AS settings can be saved as defaults....Tadjio wrote:I'm new to Bibble/ASP - I have just found how to save a preset but can I amend the 'default' settings without a preset?
Adjust image as needed, then right click on thumbnails, settings, save as raw default.
Use the advanced tab and make sure all the stuff you want to save as a default is ticked and everything else is off.
cheers
afx
