AfterShot Pro Red-Eye Correction
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Is there any way in ASP (or Bibble) to achieve Red-Eye Correction in a comparable way to PaintShop Pro?
Perhaps a plug-in?
Perhaps a plug-in?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Gerard2
- processor: AMD Athlon II X4 620 2.61GHz
- ram: 4GB
- Video Card: Ati radeon x1950xtx 512 mb
- sound_card: onboard
- Monitor/Display Make & Model: Dell FP2007
Re: AfterShot Pro Red-Eye Correction
there used to be a plugin. I am not sure if that one gets ported to ASP.
Rey - Red Eye Remover
It is made by tintin (same developer as wavelet sharpen / noise / zframe /zperspector etc... May be worth to ask.
Tadjio
- sound_card: Sound
Thanks, I can't see it in the AfterShotPro.com list of plug-ins.Gerard2 wrote:there used to be a plugin. I am not sure if that one gets ported to ASP.
I can wait...
Tadjio
It isn't in the list, tintin hasn't mentioned its future one way or another yet.
In the meantime using circle regions (don't forget to create a layer first if you're new to ASP/Bibble) that fit the red eyes reasonably closely and with a small feather (in a test shot I tried just now to check in ASP, I used 56 pixels with 8 feather on an 18MP image). I find that reducing exposure of the layer by 1-2 stops and decreasing the saturation to -50 to -75 gives good results.
Regards
Rick.
Regards
Rick.
Tadjio
- sound_card: Sound
Thanks, Rick. I am new to ASP/Bibble and I think I'll resort to PSP as External Editor until a plug-in comes along, apart from playing with your suggestions...
Tadjio
Gerard2
- ram: 4GB
or try to bounce your flash, or dont flash straight in the eyes, then you wouldnt need a repair..
Anyway, i would prefer to work with ASP even with images that need red eye correction or some other dust removal. THen you would just open them in an external editor like psp (i have an old version of PS elements) and touch the pixel data op. Keep in mind that ASP is a RAW editor that is most usefull if you have quite a few images at once.
Tadjio
- sound_card: Sound
... or just don't take photos of people ...Gerard2 wrote:or try to bounce your flash, or dont flash straight in the eyes, then you wouldnt need a repair..
I try to follow all these suggestions but on the rare occasion that I have Red Eye, I usually use PSP's excellent facility so I will carry on doing so from ASP using PSP as an External Editor, until a better plug-in solution arrives!
Tadjio
tintin
- processor: Ryzen R5 3600X
yeah, right. this plugin exists for B5 - and i think it is worth to be updated for ASP. but takes a bit, since i'm still busy with some ohter plugins...Gerard2 wrote:there used to be a plugin. I am not sure if that one gets ported to ASP.
Gerard2 wrote:same developer as wavelet sharpen / noise / zframe /zperspector etc... May be worth to ask.
br,
tintin
Tadjio
- sound_card: Sound
Thanks for the update, tintin - I can waittintin wrote:yeah, right. this plugin exists for B5 - and i think it is worth to be updated for ASP. but takes a bit, since i'm still busy with some ohter plugins... :?tintin
What other plugins can we expect for ASP from you?
Tadjio
Tadjio
- sound_card: Sound
Thanks very much tintin, I will peruse the list and wait with bated breath...
Tadjio
Gerard2
- ram: 4GB
And my apologies for mixing plugin developers Tintin and Spoilerhead!
Tadjio
- sound_card: Sound
They are all names I am beginning to recognise and respectGerard2 wrote:And my apologies for mixing plugin developers Tintin and Spoilerhead!
PS Another such name is 'afx'. What is the plugin 'andrea' that I have heard mention of?
Tadjio
afx
- System_Drive: N/A
- Video Card: FirePro 4900
A very cool Film emulator by Sean Pucket (http://nexi.com/328). AS is incomplete without itTadjio wrote:What is the plugin 'andrea' that I have heard mention of?
Sean is working on an AS version, so it is just a matter of days or a few weeks max I think before this shows up.
cheers
afx
claudermilk
Sean was one of the first to start writing Bibble plugins IIRC. He generated quite a number of excellent ones. I miss Andrea...
Bibble transplant
