AfterShot Pro Perspective Correction [zPerspector Plugin]
AfterShot Pro Plugins
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Re: AfterShot Pro Perspective Correction [zPerspector Plugin
Post by Tadjio »
Now that I have tried the zPerspector Plugin and compared it with Perspective Correction in PaintShop Pro, I think it is great.
Attached is a quick ASP sample of Sherborne Abbey that I tried in both programs.
Sherborne Abbey AfterShot Pro Perspective
The controls are very different in use compared with PSP, which relies on dragging the corners, but I think they work very well.
My only concern is that in PSP I usually have to apply a 'Deform', eg reduce the Height to 95%, to get the right perspective, but I don't know how to do this in ASP. Any suggestions?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
DaveQ
motherboard: Acer Aspire Ethos 8950G
processor: Intel Core i7 2630QM
ram: 16Gb DDR3
Video Card: AMD Radeon HD 6850M 2Gb DDR5
sound_card: Creative Labs 5.1 Surround Sound
Hard_Drive_Capacity: SSD 1Tb
Monitor/Display Make & Model: Acer 18.4" HD+ LED clear.fi
Corel programs: PSP X9, 2018 64-bit. AFS Pro 3
Post by DaveQ »
A GREAT Plug-in! I have run a couple of images through it and it performs fantastically. Thank you so much. :lol:
andysalay
operating_system: Linux
System_Drive: Z
motherboard: ASUS P5E WS PRO
processor: Core2 Quad Q6700
Video Card: AMD Radeon HD 6670
Post by andysalay »
Tadjio wrote:My only concern is that in PSP I usually have to apply a 'Deform', eg reduce the Height to 95%, to get the right perspective, but I don't know how to do this in ASP. Any suggestions?
Unfortunately (if the plugin is more or less unchanged port from B5), there is no such function.
I have a discussion with TinTin in the past, I would welcome nonlinear resize in zPerspector.
Because by intensive perspective correction the relative size of some objects is changed - quite noticeably, I think this can be corrected by nonlinear resizing.
Non linear resize tool example
Please note the uneven resize of upper and lower half of the image. This is normal and expected of course.
But after precise application of non linear resizing, the differences should be eliminated. And because on my example the zPerspector settings are symmetrical according to vertical axis, after perspective correction I can use resize along this vertical axis.
I do not have corrected preview, because I realized the example software is somewhat lame and does not enable to set pivot point of resize.
But it should be obvious from the link, what the software does.
What do you think?
Andy Salay
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 650
sound_card: Asus DX
Hard_Drive_Capacity: Lots
Monitor/Display Make & Model: NEC PA272W
Post by bananahead »
What about if you change all four vertical sliders equally ? (Andy has just changed the top two)
Tadjio
sound_card: Sound
Post by Tadjio »
I have a discussion with TinTin in the past, I would welcome nonlinear resize in zPerspector.What do you think?
Andy Salay
I read through your links and I think what you are looking for is PaintShop Pro as an External Editor :)
PSP has extensive Pick/Deform and Warp Tools - here is an example of the Pick Tool dialogue:
PSP Pick/Deform Tool
In practice I only adjust either the ScaleX(%) or ScaleY(%) to say 95% until the result looks right!
Tadjio
bobm185
Post by bobm185 »
I'm new to ASP and Bibble plug-ins - so I hope you don't mind this question. I've installed the Corel plug-ins (with the .afzplug extension) without any problems. I can't install the Bibble plug-ins (.bzplug). How are you checking out the zPerspector plug-in in ASP? Any help would be appreciated! Bob
DaveQ
ram: 16Gb DDR3
Post by DaveQ »
bobm185 wrote:I'm new to ASP and Bibble plug-ins - so I hope you don't mind this question. I've installed the Corel plug-ins (with the .afzplug extension) without any problems. I can't install the Bibble plug-ins (.bzplug). How are you checking out the zPerspector plug-in in ASP? Any help would be appreciated! Bob
Tintin provided the download link on the previous page: http://support.bibblelabs.com/forums/vi ... 98&t=19780
bobm185
Post by bobm185 »
Thank you DaveQ. I missed the detail and assumed it referred to the Bibble version. I got my "af" and "b" extensions mixed up. Thanks again - Bob
Tadjio
sound_card: Sound
Post by Tadjio »
Tadjio many moons ago wrote:Coming to ASP after using PaintShop Pro (PSP) for a long time, the major feature I miss from PSP is Perspective Correction.
If we had a comparable feature in ASP, this would reduce the need to call PSP as an External Editor.
I have now been using the zPerspector PlugIn a lot for Perspective Correction in ASP and the more I use it, the more I prefer it to the facility in PSP :)
There is one pair of controls, however, that seem to me to be counter-intuitive: The Lower Left Corner and Lower Right Corner Up/Down sliders. They should move in the opposite direction!
Tadjio
tintin
processor: Ryzen R5 3600X
Post by tintin »
Tadjio wrote:There is one pair of controls, however, that seem to me to be counter-intuitive: The Lower Left Corner and Lower Right Corner Up/Down sliders. They should move in the opposite direction!
all the 8 sliders are implemented to move the corners out by turning the mouse wheel upward and to the inner when turning the mouse wheel downward.
changing this for just that both sliders would break the ui somehow.
br,
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
Tadjio
sound_card: Sound
Post by Tadjio »
br,
tintin
It's difficult to explain other than by doing it! I am talking about the slider, not the mouse wheel.
Moving the upper-left corner up/down is fine :-
  • Mouse wheel up, drag slider up, all increase the numerical value and move the corner up.
however...
Moving the lower-left corner up/down is odd :-
  • Mouse wheel up moves the corner outward (down) as I would expect.
    Slider up moves the corner inward (up) which is wrong to me (and reduces the numerical value).
I can live with it, but I still feel it is counter-intuitive when using the slider!
Tadjio
Tadjio
sound_card: Sound
Post by Tadjio »
Tadjio wrote:Moving the lower-left corner up/down is odd :-
I haven't made myself clear - when I say 'slider up' I am using the arrow keys (not dragging the slider, which works ok).
Let me just try and explain this another way:
Using the arrow keys on the top row sliders 'move upper-left corner left/right' and 'move upper-right corner left/right' work in equal and opposite ways, so why don't 'move upper-left corner up/down' and 'move lower-left corner up/down'? :?:
I give up - I think this is going to be too difficult to change... :roll:
Tadjio
gareth
operating_system: Windows 8.1
motherboard: Acer Aspire TC-605
ram: 12Gb
Video Card: NVIDIA GeForce GTX 745
Hard_Drive_Capacity: a few TB
Monitor/Display Make & Model: AOC 2369M sRGB
Post by gareth »
The mouse wheel and keys work the same ( push/up = bigger , more positive value )
You are right that it might be more logical for the mouse wheel (pull) and arrow(down) to move down on on the lower up/down sliders
but that logic would not work with left and right so I think it is better to stay with up = bigger number! :)
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
