AfterShot Pro RAW+JPEG [or can I sort/filter by Type?]
andysalay
operating_system: Linux
System_Drive: Z
motherboard: ASUS P5E WS PRO
processor: Core2 Quad Q6700
Video Card: AMD Radeon HD 6670
Re: AfterShot Pro RAW+JPEG [or can I sort/filter by Type?]
Post by andysalay »
hannes_hab wrote:(sort)/filter can be done in file system mode too:
- go to a raw file you have not edited yet
- set the green "picked" flag
- settings -> save as raw (or camera) - default
thats it - all your new downloaded raw files from CF/SD card have the green flag - the jpgs don have it
you can do ctrl R - to apply the default settings to older images ...
It is a nice workaround, but, it did not move our feature request into useless area, because this workaround blocks natural usage of flags (Pick/Reject). We need these flags for what they were made for.
Regards
Andy Salay
EDIT: typos
ChrisC
motherboard: Intel HM65
processor: Intel Core i7
ram: 8 GB DDR3
Video Card: AMD Radeon HD6770M
sound_card: Beats Soundsystem
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
Post by ChrisC »
That's another great solution. I was not sure whether the raw defaults get applied during download or only during import.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
ChrisC wrote:That's another great solution. I was not sure whether the raw defaults get applied during download or only during import.
Download does not apply anything.
Import and viewing them the first time in the file browser will do it.
cheers
afx
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
andysalay wrote:It is a nice workaround, but, it did not move our feature request into useless area, because this workaround block natural usage of flags (Pick/Reject). We need these flags for what they were made for.
I agree that we nevertheless need some native support in ASP for this situation.
But if you don't like to use the 'picked' flag you could instead use one of the color lables.
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
cheers
afx
So one needs to import the images into a catalog anyway?
rawshoter
processor: Dualcore
ram: 4 GB
Video Card: ATI - 1GB
Post by rawshoter »
But if you export those Raws as Jpeg or Tiff into the same folder, as I do usually, the Jpegs will get that same flag to. :wink:
Fraenzken
ram: 4 GB
Monitor/Display Make & Model: IIyama ProLite E1900S
Post by Fraenzken »
You can create a preset that deselects the flag. And then apply this preset in the output batch queue.
grubernd
System_Drive: N/A
Post by grubernd »
ah, those were days when RAW+JPG were treated as one..
after initial rename i just dump the JPGs into a subfolder..
if i let the camera create them, that is.
output is kept separate from the RAWs, anyway.
Bibble since 2004. Aftershot until 2020. From then on darktable.
rawshoter
processor: Dualcore
ram: 4 GB
Post by rawshoter »
Fraenzken wrote:And then apply this preset in the output batch queue.
Thanks for the useful hint, Fraenzken. I didn´t thought on that part.
-cr
System_Drive: N/A
Post by -cr »
Great tip, thanks!
(Although I never bother with JPEGs, anyway, when RAW is available. :)
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
After afx's hint I am not sure if this is working as expected!
> If you still need to import the images to apply the default RAW settings then you can simply use the file type info of the Metadata Browser!?
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
I think afx meant "viewing them the first time" applies the settings - not downloading ...
You can see the green flag when going to the place where your images are.
No need to import to the catalog.
Try by yourself ...
and - shure - its only a workaround -
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
I did a quick test with existing images. I set a blue label to a jpg and saved this as the rendering default. Browsing other folders with jpgs did NOT show the blue label. Only after CTRL+R (Apply default settings) the label shows up.
and as you said:only a workaround
What I am interessted in is: what would be your prefered feature to support your workflow?
Staking the RAW and jpg? Would this be enough?
When I shoot RAW and JPG I do this only because sometimes the jpg generated from the camera is a perfect reference that I hardly achieve. Otherwise I would only shoot RAW.
So my workflow needs a step where I have to decide whether the developed RAW or the JPG is the one to keep.
grubernd
System_Drive: N/A
Post by grubernd »
i never mix output from RAW and JPG if it can be avoided.
the look, rendering, sharpening, structure and so on of the image just wont match unless you use software made by the camera manufacturer. and not even that is a guarantee. since i currently use cameras from three companies that is out of the question. also i have yet to see an JPG out of a camera that i am really pleased with. i use JPGs, yes, but i dont like them.
i shoot JPG exclusively for workflow reasons - quick deliveries on sight where there is no time to adjust and render from RAW is my most common usage. a colleague who does 360° panos has to shoot so many images to get the 360° with full dynamic range that he very often shoots jpgs because HDR is maxing the dynamic range anyway and he can fit more locations on a card while shooting.
PS: the Ctrl-R behaviour is by design - otherwise changing your defaults would mess up any image you look at. even those that were done before the new defaults.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
ChrisC wrote:When I shoot RAW and JPG I do this only because sometimes the jpg generated from the camera is a perfect reference that I hardly achieve. Otherwise I would only shoot RAW.
Before I got AfterShot Pro, I shot in RAW+JPG because my Canon JPG Images (with Picture Styles applied) very often don't need much further editing and so there was no purpose in using Canon's DPP for RAW Conversion.
Now with AfterShot Pro of course the RAW Conversion is much easier but I still have to apply more editing to improve the Sharpness and Lighting, so it is often easier still to start with the JPG.
When I want to adjust Exposure, Highlights, Shadows, Noise etc., I still start with the RAW Image.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
