Picture Window "Jumping" When Making Changes
frombrandon
- Hard_Drive_Capacity: 1.5 TB
Whenever I make any sort of slider adjustment (or any adjustment at all) the picture shifts (jumps? shakes? flickers?) ever so slightly as it goes pixely until the change has been processed. Any idea why this is happening and how to fix it? I'm enjoying ASP, but when making adjustments — especially a lot at one time — the flickering image drives me nuts.
I'm on a 2.53 GHz Intel Core 2 Duo Mac Mini (OSX Lion)
8GB of RAM
*Plenty* of disk space
Thanks!
8GB of RAM
Thanks!
springm
- System_Drive: Q
Re: Picture Window "Jumping" When Making Changes
frombrandon, I guess what you see are simply intermediate stages of the re-calculation of the image to make it match the adjustments.
Markus
Markus
My blog: http://markus-spring.info
frombrandon
But I'm not seeing this in the demonstration videos. I'm not running the bare-minimun system requirements, so I can't understand why it's doing it.
springm
- System_Drive: Q
Well, I am on a quadcore with 4GB memory, and I do see it. Maybe the resolution of the demo videos is small enough to make it invisible.
Markus
Markus
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Been seeing it for ages ;-(
a one pixel jump....
Sucks major when trying to judge fine adjustments.
cheers
afx
cheers
afx
frombrandon
Well, Corel responded to me on Twitter and provided a solution that works for me. I ended up just needing to switch High Quality Previews on. I'm guessing this adds a teeny bit of time to the processing, but having that flickering gone makes all the difference.
That's, File>Preferences>Display toggle with 'Show Only High Quality Previews'
springm
- System_Drive: Q
Thanks, Brandon, I will try this!
Markus
Markus
afx
- System_Drive: N/A
Unfortunately, that is no help, this one pixel jump also occurs when quality previews only are selected....
cheers
afx
cheers
afx
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
I see a difference. It was more than one pixel but now it's as afx says, one pixel jump.
Regards, Dan
DaveQ
- motherboard: Acer Aspire Ethos 8950G
- processor: Intel Core i7 2630QM
- ram: 16Gb DDR3
- Video Card: AMD Radeon HD 6850M 2Gb DDR5
- sound_card: Creative Labs 5.1 Surround Sound
- Hard_Drive_Capacity: SSD 1Tb
- Monitor/Display Make & Model: Acer 18.4" HD+ LED clear.fi
- Corel programs: PSP X9, 2018 64-bit. AFS Pro 3
This certainly worked for mefrombrandon wrote:Well, Corel responded to me on Twitter and provided a solution that works for me. I ended up just needing to switch High Quality Previews on. I'm guessing this adds a teeny bit of time to the processing, but having that flickering gone makes all the difference.
Fraenzken
- ram: 4 GB
- Monitor/Display Make & Model: IIyama ProLite E1900S
... no pixel jump here either after activating the high-quality previews.
Cheers
Frank
Cheers
Frank
my photos: http://naturfotos.bplaced.net
Rob Greenstein
- motherboard: ASUSTek Computer INC. LITHIUM 1.04
- processor: 3.00 GHz Intel Pentium D
- ram: 4GB
- Video Card: ATI Radeon X300_X550_X1050 Series
- sound_card: Hauppauge WinTV PVR PCI II [26xxx]
- Hard_Drive_Capacity: 2.135TB
- Monitor/Display Make & Model: HP f2105
Even with the Preferences set for High Quality, there are times when a change to the rendering features, Noise Reduction, Sharpness, and other controls fails to refresh the main image, until the cursor is returned to or clicked on the main image portion of the screen.
Robert S. Greenstein, Esq.
Entertainment Industry Business & Legal Affairs
Greenstein Law Offices, Woodland Hills, CA USA
● AfterShot Pro & PaintShop Pro X4 Ultimate
● Canon EOS-1D Mark II N
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
Hi,Rob Greenstein wrote:Even with the Preferences set for High Quality, there are times when a change to the rendering features, Noise Reduction, Sharpness, and other controls fails to refresh the main image, until the cursor is returned to or clicked on the main image portion of the screen.
thanx that you mention this ... I also observe this behavior sometimes (seems to miss a trigger/event to really put the results into the window ?) ... also with B5.2.2 and B5.2.3 .
And about the "Jumping" .... yes and no ... sometimes I could see it, but most of the time I only get some "coarse" intermediate image before the good one.
cheers
Markus
OpenSuse 11.4 (32bit)
Dell U2410
Dell U2410
Rob Greenstein
- ram: 4GB
Most of the times when I have noticed the hesitation (i.e. image not re-rendered showing the effect of any change to the control panel's tool) it has been a subtle effect. Almost so imperceptible, that, at times, I mistook that the change had already been applied and I just didn't notice it.
If there were a visible "processing" message (or other brief and small transparent overlay on the image) indicating that the processing was still underway -- and it disappeared when the image was fully re-rendered -- this would be unequivocally clear. For systems fast enough, the feature could be turned off in the Preferences, or it would appear and disappear so rapidly as not to matter for users of such high speed systems.
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
