Just a quick test.
Denis de Gannes
motherboard: Gigabyte- G31MX-S2
processor: Intel Core Quad CPU Q6700 2.66 GHz
ram: 4GB
Video Card: On Motherboard
sound_card: nk000
Hard_Drive_Capacity: 1820 GB
Monitor/Display Make & Model: AOC 2216Sw
Just a quick test.
Post by Denis de Gannes »
The file is a test file from my Olympus E510 at ISO 100. I use this to make comparisons with the various raw converters I use.
On the left is the process done with Olympus Viewer 2.0 software, the camera provided software. The center is done with Lightroom 4.0 Beta, on the right is ASP with Perfectly Clear and WS Plugin enabled. While the ASP rendition is more punchy I am very pleased with the rendition. The LR rendition is the closest to the actual objects captured.
http://www.dpreview.com/galleries/92036 ... image00085
Denis
Camera: Oly E300 & E510; ZD & OM Lenses; Panasonic G3
Software: PSP x4; Corel Video Studio Pro X3; PS CS6; SilkyPix 4; ASP 1; LR 5.4; Capture One Ex 7; Qimage Ultimate; VueScan.
quadrox
operating_system: Linux
motherboard: ASUS P6T
processor: Intel Core i7 920
ram: 12 GB
Video Card: AMD Radeon HD 5870
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: DELL U2410
Re: Just a quick test.
Post by quadrox »
I do hope you realize that by enabling "Perfectly Clear" you invalidated your results for AS? The entire point of PC is to punch up your photos, so enabling it and then saying the Lightroom rendition was more realistic is kind of disingenious.
Please note that I am the last person to defend AS (or the old Bibble), but I'm not entirely sure what your point was with this experiment?
Denis de Gannes
ram: 4GB
sound_card: nk000
Yes, I am quite aware that PC would have that effect. All raw converters produce different renditions of raw files. e.g. Bibble 5 had several different profiles that produced results intended for different uses.
Using the particular file to view and compare the different renditions is useful to me since the items in the photograph are present in my home for me to compare. The statement that Lightroom produced a result that was the closest to reality is just to put things in perspective and not to suggest that it is better or more pleasing.
Denis
quadrox
ram: 12 GB
Post by quadrox »
I see, thanks for explaining that. And I hope you didn't take offense at my post :)
tomsi42
Post by tomsi42 »
Denis de Gannes wrote:Yes, I am quite aware that PC would have that effect. All raw converters produce different renditions of raw files. e.g. Bibble 5 had several different profiles that produced results intended for different uses.
The problem is of course, people don't look at it that way. They will read better/worse into any comparison.
When I test and compare raw converters, I try to get a reasonalbe overview on how they work, then take some of my photos and see how easy it is to get to the results I want.
claudermilk
Post by claudermilk »
tomsi42 wrote:When I test and compare raw converters, I try to get a reasonalbe overview on how they work, then take some of my photos and see how easy it is to get to the results I want.
That's the best way. It's all subjective in the end anyway, so whichever tool allows you to get to your desired end the easiest way is the winner--for you.
Bibble transplant
