If I go into my computer, select a drive and left click it to open , then the Paintshop Pro X4 will start uo. If I right click it will say " browse with Corel Paintshop pro X4) . had a similar problem with icons. Called tech support and they sent some patches along that fixed that part of the problem.
my goal is to get rid of all the auto openings> Any help appricated
PS pro X4 ow do you remove tthe browse With PS Pro
Cathy1947
- motherboard: Compal30F3 99 B6
- processor: 2.00 gigahertz
- ram: 4GB
- Video Card: Mobile Inter R 45 Express Chipset Microsoft
- sound_card: IDT High Defination Audio CODEC
- Hard_Drive_Capacity: 500Gb
- Monitor/Display Make & Model: Generic PNP 17.2 vis
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
Re: PS pro X4 ow do you remove tthe browse With PS Pro
...allready discused in this forum.
Corel removed in X3/X4 this options. You can remove *key* in Windows registry. But after while it will be back.... I do not know permanent solution. Can someone help..? Thanks.
PSP X4: How do you remove the "Browse With PaintShop Pro X4"
deleted
Radim
- ram: 4GB
As I wrote before. Info about removing was already posted with adequate REGISTRY keys. But after while it is *back*. So I left it...
