Custom White Balance Problem
springm
operating_system: Linux
System_Drive: Q
Post by springm »
Picking a neutral spot in this image creates a white balance setting, that delivers everything but a neutral color on the sample point:
Panasonic G3, auto white balance in camera, pick custom white balance at cursor spot
The green cast even after the attempted white balance setting shows both in the curves and in the figures in the lower right corner.
Any idea how to correct this?
Markus
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Custom White Balance Problem
Post by afx »
can you provide the raw file?
cheers
afx
springm
System_Drive: Q
Post by springm »
afx
System_Drive: N/A
Post by afx »
Ouch.
As shot is fine. Click white is a green nightmare. Something is broken here.
I think the bibble upload site for problem images still works, I suggest sending it in.
cheers
afx
springm
System_Drive: Q
Post by springm »
Thanks, Andreas.
I will upload it there.
Markus
quadrox
motherboard: ASUS P6T
processor: Intel Core i7 920
ram: 12 GB
Video Card: AMD Radeon HD 5870
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: DELL U2410
Post by quadrox »
Ah, I have had a similar issue with one of my shots, but not as clear as in your example. I was thinking that my eyes were wrong, but it seems that click-white is indeed broken.
quadrox
ram: 12 GB
Post by quadrox »
springm
System_Drive: Q
Post by springm »
quadrox wrote:Ah, I have had a similar issue with one of my shots, but not as clear as in your example. I was thinking that my eyes were wrong, but it seems that click-white is indeed broken.
OK, so this might become sort of a litmus test for the new company. I uploaded my raw file on the old bibble site and am now looking forward for a reaction, or, better, a fix.
Markus
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
I sure hope that ASP didn't use PaintShop Pro's white balance engine. It's the worst thing in the world when it comes to white balance.
Regards, Dan
springm
System_Drive: Q
Post by springm »
Strange enough, "pick grey" from the curves tool does a much better job than the white balance picker:
color balance when using the grey picker
Note that the balance is much better now, but the level of blue is still not sufficient when looking at histogram and at the values in the bottom line.
I have uploaded my raw file on the bibble website, but gotten no reaction. It would be nice if Corel/Bibble developers would acknowledge it.
Markus
-cr
System_Drive: N/A
Post by -cr »
Same here, with a couple of shots. :-/
(Worked around this by using the WB temp+tint sliders.)
Please (let Bibblelabs) fix this, Corel!
claudermilk
Post by claudermilk »
Seeing this, I tried the click white balance and can confirm I'm seeing the same issue. Nasty green tones. Doesn't matter whether I pick the black, grey, or white droppers. This is a new bug, Bibble 5 did not do this.
Bibble transplant
springm
System_Drive: Q
Post by springm »
Hmm, now I'd just like to see if posting in the forum is sufficient as a bug report for Corel.
As the old bibble forum is still active, I'll crosspost there.
Markus
df
ram: 64gb
Post by df »
This forum is user to user. Assume that Corel is more likely not to see it than they are. If it's a bug contact them directly.
Regards, Dan
maggus
System_Drive: B
Post by maggus »
I can remember that I´ve seen this issue also with B5.2.2 and B5.2.3 on lots of my shots, but never opened a thread for this.
When I´ve some time over I´ll do some test with some pictures and post here.
And meanwhile I just do it manually (if needed).
cheers
Markus
OpenSuse 11.4 (32bit)
Dell U2410
