I've just installed ASP on Linux, Mint 11 64 bit.
First thing I noticed that shape region selection tools does not work (greyed out). Does a trial version have limited set of features?
Any one can confirm this functionality works on their Linux ASP version?
OB
shape region selection does not work
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: shape region selection does not work
They should work. Did you create a layer first?
cheers
afx
cheers
afx
mato
I think you have to add new layer.
I used them yesterday ... and they worked.afx wrote:They should work. Did you create a layer first?
cheers
afx
The only strange thing I have to investigate is that their effect gets lost if the region is tiny/small/thin and you choose a big feather ... but have to look closer to it and will create a separate thread if I can reproduce.
cheers
Markus
OpenSuse 11.4 (32bit)
Dell U2410
Dell U2410
ocherno
- motherboard: ASUS MB
- processor: AMD
- ram: 4GB
- Video Card: NVidia
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Samsung 2233sw
Jumped to early, yes... it does work after adding a layer that took me couple attempts to find out where add-layer button is
OB
OB
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Thanks for letting us know that the problem was resolved.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
claudermilk
It's not the most intuitive interface. Also keep in mind (unless something changed in ASP) that there are two kinds of layers, normal ones and healing ones. Even with the clunkiness, I'll deal with it since no other RAW converter even has the option.
Bibble transplant
