I've got rid of folders from various catalog entries by first, emptying the folder. Select all the images in the folder and version/remove version. Make sure that "delete master file" is NOT checked. Once the folder is empty you can right-click and select "remove empty folder". I can't remember whether it was with removing foders from the catalog or from the file system (probably the latter) but I had to remove some extraneous files using the explorer before I could remove the folder. In the end you can also remove catalogs in this way.fotojrb wrote:How do you delete a folder from a catalog?
I've cleaned up quite a few folders this way. I find that on occasion I come across files in various spots in the "AfterShot Pro Catalog" directory or in AppData that don't appear in the catalog and have removed them (carefully) without unpleasant repercussions.
