Hello,
I found the configuration file named PluginGroups.conf in the '~/.config/Bibble and AfterShot Plugins' (Linux) and wonder what can I do with it. It contains one section (General) with 4 listed plugins. The order of the plugins is the same as in ASP in the 2 plugin-tabs, but I have 7 plugins (including Black and White Plugin).
What can I exactly configure in that file and how? The order of the plugins? How can I find out the names of all plugins for this config-file?
Regards
Config-file PluginGroups.conf
deifl
- System_Drive: Z
- motherboard: Belarc Advisor do not work on my systems
- processor: Belarc Advisor do not work on my systems
- ram: avg gt 4GB
- Video Card: Belarc Advisor do not work on my systems
- sound_card: availible
- Hard_Drive_Capacity: avg gt 2TB
- Monitor/Display Make & Model: 10" to 24" (12.5" and 24" IPS)
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
Re: Config-file PluginGroups.conf
This link should help, I think it'll work for ASP.
http://flightofthebibbles.blogspot.com/ ... -tabs.html
deifl
- System_Drive: Z
- ram: avg gt 4GB
In Bibble i configured the tabs the way you mentioned (with the customToolsUI.txt in ~/.bibble) and if you follow the link to the bibblelabs-forum http://support.bibblelabs.com/forums/vi ... 62&t=19388 you recognize that it still works in ASP with the customToolsUI.txt. Furthermore the content and structure of the 2 files (not only that they are in different places) is completly different.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
I do not know what it is used for, but typically Qt tends to use the .config tree to store layout stuff fr Bibble and AS.deifl wrote:I found the configuration file named PluginGroups.conf in the '~/.config/Bibble and AfterShot Plugins' (Linux) and wonder what can I do with it.
cheers
afx
claudermilk
Anyone running WIn7 get this to work? I've tried, but ASP seems to be ignoring the file. I'm probably missing something obvious. I would REALLY love for this method to work--I've been sorely missing the ability to really customize the layout since Bibble 4.deifl wrote:In Bibble i configured the tabs the way you mentioned (with the customToolsUI.txt in ~/.bibble) and if you follow the link to the bibblelabs-forum http://support.bibblelabs.com/forums/vi ... 62&t=19388 you recognize that it still works in ASP with the customToolsUI.txt. Furthermore the content and structure of the 2 files (not only that they are in different places) is completly different.
Bibble transplant
afx
- System_Drive: N/A
Works like a charm on my W7 box.claudermilk wrote:Anyone running WIn7 get this to work? I've tried, but ASP seems to be ignoring the file. I'm probably missing something obvious. I would REALLY love for this method to work--I've been sorely missing the ability to really customize the layout since Bibble 4.
Anything interesting in the debug log?
If the file is used, it will be noticeable there:
Code: Select all
32302.694: using customToolsUI.txtafx
