File format mismatch on importing captured AVI
Fred S
ram: 4GB
Hard_Drive_Capacity: 1TB
Post by Fred S »
I previously used VideoStudio 10 to capture and then edit my DV Camcorder files, this was on Windows XP and I never had any trouble with this. I have just captured my final DV tape with this camcorder (I'm about to get a new camcorder) on this old PC, however I have now got a new Windows 7 PC, and am now trying VideoStudio Pro X4. I have moved this captured AVI file to the new PC but as soon as I try to import it into VideoStudio I get the following:
1081:1:3
Does anyone have any idea how I can fix this? I have used some other software to conver the AVI file into a DVD compatible MPEG2 file, so I guess I could do my editing on this instead if all else fails?
Thanks in anticipation
Re: File format mismatch on importing captured AVI
You use the term 'import', but which exact command are you choosing when you right click in the timeline: Insert Video (which is what you should be using) or Insert Digital Media (which amongst other things can read and import from a DVD)?
Fred S
ram: 4GB
Post by Fred S »
Well I had been using the Folder icon, which I now see says "Import Media Files". When I tried "Insert Video" from the File menu I now get the following error:
Catastrophic failure
17101:70:2
I also just installed my old VideoStudio10 and I get exactly the same. The file itself can be played normally (outside of VS) and I even used Windows DVD Maker to burn it as a DVD.
Keith2468
motherboard: Dell XPS 435T
processor: Intel Core i7-960
ram: 12 GB
Video Card: GeForce GTX 460
sound_card: Integrated
Hard_Drive_Capacity: 432 GB
Monitor/Display Make & Model: LG E2350
Post by Keith2468 »
I am having the same issue.
I won't be happy if it turns out the warning that should occur when the files are assembled is not issued until encoding time.
Data should always be validated on input.
Keith2468
ram: 12 GB
Post by Keith2468 »
Tried again and now it is working. No idea why.
So for now my problem seems to have mysteriously fixed itself.
