I use X4 with the update.I do the test with F550 EXR 16 megapixel file and a jpg have width of 4608, but when load the .raf file, width is only 3264 after PSP RAW load
I ask about that Problem first in Fuji Forum, and a User tell me that, the RAF contain 2 8 megapixel RAW files.The RAW converter need merge the files depend on EXR Mode the camera use.and in the example pictures, the quality is not good in noise in compare to jpg.seem PSP use only 1 of the 8 megapixel RAW and do not merge them correct.
Here are some EXR RAW .raf files.when you search for other EXR Cameras, you can find RAW files for them too.scroll much down in the link
http://www.photographyblog.com/reviews/ ... le_images/
The F600 EXR is not support currently by PSP, but i test other raf EXR Camera files and notice same Problem.so not only a F550 Problem.
I install adobe lightroom 4 public beta, here it work correct and RAW quality is good and better it get, when i load the unprocessed file (only convert to tif)in psp and do denoise and sharpen in psp.
Is it possible to enhance EXR support for Fuji Kameras in PSP RAW too?
maybe the Fuji F770 EXR support can add too, i plan to buy a F770(if not too worse objectiv, or other offer more zoom) when it come in March.F550 F600, F770 use all 16 megapixel Sensor.
Fuji EXR RAW´s have wrong width and height
photopainter
- motherboard: gigabyte p55aud3
- processor: I5 760
- ram: 4 gb
- Video Card: gforce 6600
- Hard_Drive_Capacity: SSD
photopainter
- processor: I5 760
- ram: 4 gb
Re: Fuji EXR RAW´s have wrong width and height
I see that PSP x4 with last update work with F770. but no Lens correction and the problem is in. demosaik is bad, and window frames for example contain color pixel, so RAW better not use.
after shot pro do not work with Fuji Camera.
Is there enhance support planned für Fuji Camera and special F770 ?
Its always a problem to change image catalog software, because all Tags, rating that is done, is lost.
