Where to find the lens-profiles?
Where do I find the lensprofiles, in order to add my lenses?
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Where to find the lens-profiles?
Aftershot already has a lens database you can find that by going to DETAIL tab on the right side of Aftershot then click LENS CORRECTION, you'll see there the DATABASE tab. But if your lenses are lenses are not yet in the lens correction database, then you can go to the Manual tab.
More info on the Lens Correction and Detail tab at http://product.corel.com/help/AfterShot ... tools.html
I'm sure active Bibble and AfterShot beta-user will have a much better suggestion that this one.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
WilsonC
- Monitor/Display Make & Model: Samsung SA300
One quick question...is there a way to create your own lens correction profile?
-Christopher
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Yes,WilsonC wrote:One quick question...is there a way to create your own lens correction profile?
get Hugin.
It comes with a nice tool to create your own lens correction data.
cheers
afx
brucet
When you select a lens profile make sure you check the 'Enable correction' box otherwise nothing will happen.
I found it when searching (!) for profile_nikonSLR, but it cannot be edited using Notepad (like in Bibble). I must use Wordpad instead.
Is there a manual for using Hugin this way?afx wrote:[get Hugin.
Edit:
Is this a good way:
http://hugin.sourceforge.net/tutorials/ ... e/en.shtml
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
I've never tried it but there's a howto in the Bibble forums http://support.bibblelabs.com/forums/vi ... 94&t=15277 that might help.ivars wrote:Is there a manual for using Hugin this way?afx wrote:[get Hugin.
Edit:
Is this a good way:
afx
- System_Drive: N/A
No, that is outdated ;-(ivars wrote:Is this a good way:
Use the calibrate_lens_gui tool instead. MUCH easier.
You just need an image with decent straight lines in it.
(Which is actually much harder to get then I thought, don't have some many newfangled glass covered buildings here...)
cheers
afx
the best hint i found about straight lines: create your own.
use a rope and stretch it over a contrasty background .. e.g. a white rope on your green lawn.
dont use a thin line.. you want this to be a bold line.
contrast and boldness!
and: weird as it is hugin has better chances to find straight lines with smaller image sizes,
so if you have problems try to set the "maximum image size" to something lower than the default 1600.
Bibble since 2004. Aftershot until 2020. From then on darktable.
pekkal
- System_Drive: N/A
- processor: AMD Phenom 9500 x 4
- ram: 4GB
- Video Card: NVIDIA GeForce GT 610
Lensfun
I have used lensfun (http://lensfun.berlios.de/). In (my) Linux the configuration files get installed at /usr/share/lensfun/.
pekkal
pekkal
