How does one easily bring in a batch of photos to use as you are building a project??
How to shift-select a folder of photos into VideoStudio Pro
Bronzebell
- motherboard: Acer G33T.M
- processor: Intel Core 2 Quad 6600 socket 775 LGA
- ram: 4GB
- Video Card: ATI Radeon HD 4300.4500 series
- sound_card: Creative XFi
- Hard_Drive_Capacity: 1.465 TB
- Monitor/Display Make & Model: Westinghouse L2046NV
I am trying (without luck) to shift-select all of the photos in a folder to bring into a folder that I've created in VideoStudio Pro X4. I have the folder showing up a highlighted, then go to browse, then to the folder, but with I try to drag the folder into Video Studio, it then stops showing the folder and I get a circle with a line thru it.
Re: How to shift-select a folder of photos into VideoStudio
You haven't explained what you did just before that or what you mean by created a folder in VS - do you mean a new library ? - if a library then you need to choose the 'import to library' icon (opening folder above the library pane) or if you want them in the timeline the ''Insert photo' option (right click over timeline) - this will open the browse window so you can browse to the folder on your hard drive where the photos are and open it - click on the first photo - the shift+select the last one and all will highlight - then click 'open' and all the photos will copy to VS. no dragging involved.
