AfterShot Pro - Wishlist for future versions
Zrubi
operating_system: Linux
System_Drive: N/A
ram: 4GB
Video Card: nVidia GTS 250
Monitor/Display Make & Model: DELL U2311H
Re: AfterShot Pro - Wishlist for future versions
Post by Zrubi »
I would like to stack my panorama parts together with the stiched panorama....
For this, we need to:
  • able to stack up raw images with tiffs,
  • able to handle much bigger tiffs...
Paul Wossidlo
processor: AMD
ram: 2GB
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: 15.6 inch laptop
Post by Paul Wossidlo »
I'd like to see watermarking as an export option. I realize we now have the zText plugin, which is a good workaround, but a way to add a watermark while exporting web-sized images would be useful.
Paul Wossidlo
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Paul Wossidlo wrote:I'd like to see watermarking as an export option. I realize we now have the zText plugin, which is a good workaround, but a way to add a watermark while exporting web-sized images would be useful.
Why should they implement something that already exists?
Just create Typewriter/zText/Texa preset that automatically applies a watermark and load it in the batch queue.
Been doing that for years in Bibble, still works in AS.
cheers
afx
grubernd
System_Drive: N/A
Post by grubernd »
or.. you might want to take a look at using the Post-Processing section in a BatchQ
and utilize it with an imagemagick-script with prepared images.
i prefer the precision of pixel-exact watermarks over the fuzzyness of downscaled text.
Bibble since 2004. Aftershot until 2020. From then on darktable.
LMB
Post by LMB »
Here's my wishlist (some items stolen from previous posts). My top-items are:
  • Setting metadata of multiple images at once (just like we can do with keywords)
  • Native implementation of Local Contrast Enhancement
  • Allow zoom smaller than Fit-to-Screen
  • Geotagging support (I mean, allowing me to manually select the coords from a map).
  • More responsive layer edition.
These would be nice, too, but have lower priority for me:
  • Ability to select images without any keywords, something like a [blank] function.
  • Support for tablets (pressure sensitivity) when using the brush to draw a region.
  • An option to show the master file. (But then, as someone asked, what is "original" with a raw file?)
B4b5
Post by B4b5 »
This wish is half ASP and half PSP.
I wish that:
1... PSP could access the same large collection of "ICM Profiles" that ship with ASP, and
2... Like ASP - PSP might be able to work in one color space and output in another color space.
It seems like having ASP & PSP in the same house has caused a lot of users like me to use both in combination...
A little more cross compatibility would go a long way...
afx
System_Drive: N/A
Post by afx »
B4b5 wrote:T2... Like ASP - PSP might be able to work in one color space and output in another color space.
No, never again. That lead to way too many problems and confused users in Bibble.
The current solution is perfect.
cheers
afx
lenssniper
System_Drive: N/A
Post by lenssniper »
My wishes
- bring something like "Profiles" back to ASP. A portrait has certainly different requirements than a a landscape. The current presets (which needs first do be developed by each user himself..) set always absolute values (e.g. a curve), but do not relativly modify anything (e.g. if I have 2 curves to be applied, the 2nd will overwrite the first one, instead of combining them to a new curve)
- selective Adjustements: The brush requires feathering - like the other tools.
- selective Adjustements: a "magic wand" in any form ( e.g. a brush with edge sensivity, a color-selection-Tool (just look at the power of the U-Point-Techologie of the NIK-Products and Nikon CaptureNX)
- increase limit of 30MPix per File (just look at scanner files or the new released Nikon D800) Thats where the speed of ASP could make a difference
- Library: offer users the possiblilty to store queries (e.g. "best pictures ever", selection for printing, ...)
- download/import files: Pls offer a possibility to skip already existing files (if somebody inserts a memory-card where some picture are already on the PC, they don't need to re-transferred which only takes time.)
hodgepig
System_Drive: N/A
Post by hodgepig »
The priority for me is for Corel to provide a statically linked package as per BibblePro so that AftershotPro will install/run on any version of Linux, or to provide a selection of rpms for various flavours and ages of Linux. The current package is dynamically linked to a very new version of a shared library and will not even install on my ~2 year old Linux box (running opensuse 11.2). It's running fine on my Mac however, but that's a laptop for occasional use, not my main machine.
By the way, please update this forum so that it doesn't demand a "drive letter" etc. which is meaningless in Linux and MacOS.
As for features an absolute priority for me is support of Fuji X100 RAF files. I can't even use ASP with my second camera at the moment. This was requested regularly to Bibble over the last year or so.
Once the above are fixed and I can start using the software, I'm sure I'll have more suggestions!
darKing
Post by darKing »
cheers
afx
That doesn't necessarily mean you can choose different spaces to work with. ;)
LMB wrote:Here's my wishlist (some items stolen from previous posts). My top-items are:
    [\quote]
    This woul be helpful for... what? :?:
afx
System_Drive: N/A
Post by afx »
darKing wrote:That doesn't necessarily mean you can choose different spaces to work with. ;)
Exactly. There is no need to choose working spaces. The concept is broken.
[*] Allow zoom smaller than Fit-to-Screen
If you currently look at a 200x200 JPG on 1600x1200 screen, it will be upsized to fit to screen (or preview area actually) instead of being shown at 200x200....
That is yucky.
cheers
afx
B4b5
Post by B4b5 »
cheers
afx
Hi darKing; you got it right! :wink:
Hi afx;
I understand and completely agree with the absolute prohibition against commingling ASP & PSP Working spaces, but we souldn't allow
misreading of the language to prevent the improvement of a perfectly good post process tool like PSP. This is a one way street
that changes nothing in ASP, and provides no route whatsoever into any aspect of ASP...
I never said "Working space"; I said "Color space" - as in "Pro Photo" vs "sRGB" or "Adobe RGB"...
Your signature line says - sRGB clipping sucks and Adobe RGB is just as bad. - I agree with that and am only trying to help everyone else get there. PSP currently offers me only sRGB Color space.
darKing
Post by darKing »
afx wrote: Exactly. There is no need to choose working spaces. The concept is broken.
Something is lost in translation here. Someone is not getting it, it's either you or me.
He said: "T2... Like ASP - PSP might be able to work in one color space and output in another color space." (that means other than sRGB)
That is yucky.
eek :shock: never did this. So I never thought of it.
BTW: You really should think about putting "broken by design" in your sig ;)
afx
System_Drive: N/A
Post by afx »
B4b5 wrote:I understand and completely agree with the absolute prohibition against commingling ASP & PSP Working spaces, but we souldn't allow
Oops sorry, did misread that one sentence...
I thought PSP is a serious editor? Puzzled....
cheers
afx
B4b5
Post by B4b5 »
afx wrote:Oops sorry, did misread that one sentence...
I understand, we bibble transplants don't want to allow anything to screw-up the worlds best Raw image software. Corel is lucky...
afx wrote:I thought PSP is a serious editor? Puzzled....
cheers
afx
I'm new to PSP so can't judge seriousness. Although I can see it producing nice artistic results AS A POST PROCESS - don't get excited, I said post process! :lol:
