I recall in earlier versions of PSP that this was available.
I found it very useful.
I cannot find it in X3. I read that shift+G enabled it (in X4 only?) but I can´t see where it is.
Please advise
Gamma correction PSPX3
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Gamma correction PSPX3
The Gamma Correction command is hidden.
Go to View->Customize.
In the Customize dialog under the "Commands" tab find the label "Unused Commands" inside there you will find the old Gamma Correction command. Drag it into any menu or toolbar. If it doesn't have a shortcut key and you want it to have one you can set that under the "keyboard" tab in the "Customize" dialog.
Otherwise there are a number of commands with Gamma correction options. I believe Corel has placed this in the unused commands list because they think other filters do well enough.
caspia1
- ram: 16gb
- Hard_Drive_Capacity: 1Terrabit
- Monitor/Display Make & Model: twin hp displays
- Corel programs: Pro 2023 Ultimate
Brilliant! Works fine now. Many thanks for the quick response.LeviFiction wrote:The Gamma Correction command is hidden.
