Starting today some of X4 windows (14.1.0.5) are not tall enough.
The Adjust Color Balance window appears normal size however the contents are in the advanced mode so most of the controls are not available. Likewise the top of the histogram palette is chopped off so that the highest RGB value displayed is about 170. No difference with tab mode on or off. Similar problem with the editing window but zooming out is a work around.
This started today and no changes have been mode to the system (W7). Rebooted just for grins and no change.
Is there a file or registry setting I can delete? Re-install?
Thanks.
Larry
X4 windows clipped
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: X4 windows clipped
You can try updating your DirectX by downloading it from at http://www.microsoft.com/Windows/window ... tx-11.aspx or reset your workspace... You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
LarryP
- motherboard: Asus 1156
- processor: Intel i7
- ram: 12G
- Video Card: Nvidia GTS-430
- sound_card: default
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: HP 2159m
The work space reset fixed the adjust color window. The histogram is not right but that is not so critical.
Thanks.
Larry
Thanks.
Larry
