VS X3 Error - "Cannot start the capture graph"
conservative-dad
motherboard: Acer Aspire X3400G
processor: 3.10 gigahertz AMD Athlon II X2 255
ram: 4Gb
Video Card: NVIDIA GeForce 9200
Hard_Drive_Capacity: 3 Tb
Monitor/Display Make & Model: DELL E177FP
Post by conservative-dad »
I have the VS X3 version and am trying to capture a VHS tape to VS. I'm using the ION "Video 2 PC" capture card and I have hooked up the 3 RCA cables (red, white and yellow) to the capture card and then via a USB port attached the capture card to the computer. The USB device is recognized in Source by VS X3 and is called "USB 2861". The Format automatically is automatically set to "DVD". The capture video icon is blinking and when I click it to capture, I get the error message "cannot start the capture graph". I can't go any further from this point. Any ideas on what I should do or check or what this error message means?
Re: VS X3 Error - "Cannot start the capture graph"
Post by Trevor Andrew »
Welcome to the forums
I know there was some issues with VS 3 and capture, whether this was related to USB capture I do not know, Others users may expand on this.........
Capture Tab
Source to DVD
Select / allocate a capture folder
There is an Options Cogwheel that allows you to set the “video properties”.
Select the correct Input Source as Composite and the TV system, Pal or Ntsc
Audio to USB
Then choose the Template Tab
Make sure the VHS video is running and the preview showing the video, then press capture.
If you still have problems the device should have been bundled with a Video Converter that will allow capture. I did a search and found some reference to EZ Video Converter software.
