I had a file that the L audio channel is English and the R audio channel is Chinese, so I want delete L audio channel.
How can I do that? I using VS Pro X4 Ultimate.
How can I delete L or R audio channels
Michael_HKG
Re: How can I delete L or R audio channels
There is an option to duplicate audio channels, I think it may work, try it on a test file first.
With the video in the top track switch the view to Sound Mixer (wav icon immediately above timelines)
Select the clip then select the Attributes Tab
Tick Duplicate Audio Channel, choose Left or Right then play in project playback mode.
I have not used this option so you will have to run your on tests.........
It will be interesting to know whether that option works Michael - I have used it when I had videos with only a mono track recorded on one channel - then it duplicates the sound to produce a sort of 'twin' mono using both tracks - but will it overwrite a sound track already there ?? that's the question I can't test because I do not have a video with different audio channels - so I would be interested to know what happens.
Michael_HKG
ok. I try it.
