Removing content from a vector shape
Torrianthane
operating_system: Vista Ultimate
motherboard: Acer EM61SM-EM61PM
processor: AMD Athlon 64 X2 Dual Core 3800+ 2.00Ghz
Video Card: NVIDIA GeForce 6150SE nForce 430
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 54.21 GB
Monitor/Display Make & Model: DELL 2208WFP 22.0"
Post by Torrianthane »
Hello,
I am tracing a simple raster shape in a new vector layer and I want to know how I can remove a portion of the content from the center. Picture a shape like a letter "o" where there is shape data comprising the perimeter ring, and no shape data in the center. I trace the perimeter of the the shape making a solid eliptical-type shape, but I need to then remove a portion of the center of the shape so that only the ring of the O has vector data. How can I do this?
Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Removing content from a vector shape
Post by LeviFiction »
You need to reverse the contour.
Okay maybe that wasn't the best explanation.
When you create a second contour in the current vector object, you either create it in reverse order of the contour you want to cut a hole into (clockwise and counterclockwise) or select the second contour and in the Object menu select "Reverse contour" (I can't remember if it's in the "Edit" submenu or not but it is there somewhere).
When the two contours are going in opposite directions PSP interprets that as a "cut" in the vector.
