How do you get rid of a halo??
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Post by pdxrjt »
I think this is a common problem and I believe I've read about it somewhere, but can't find much help now. I did a selection which I masked, on Stonehenge. Then I tweaked the sky quite a bit. However, the actual Henge (when it is unmasked) seems to have a small light "halo" around it. (Not sure hot to attach a pic) I've tried several things, but none do a great job. Tried feathering the selection a few pixels, tried burning the halo, tried "smudging" the halo into the sky, but it still looks a bit unnatural. There may not be a good solution and the picture looks OK, but I think it would look much better without the halo.
See the small white line around the stones
Gods R Angry.tif (114.5 KiB) Viewed 1820 times
Adverts for Corel products when you close PSP don't bother me.
brucet
operating_system: Windows 8.1
Re: How do you get rid of a halo??
Post by brucet »
Make sure your selection is set to 0 on both Feather and Smoothing and you should get a clean line.
Otherwise you may try Cloning some of the sky back towards the subject.
pdxrjt
ram: 32 GB
Post by pdxrjt »
brucet wrote:Make sure your selection is set to 0 on both Feather and Smoothing and you should get a clean line.
Will check into feather and smoothing, will look into the cloning too. Thanks
